Venture 1997-2005
Platform: U-Body
front brake caliper bolts, what is the difference between top and bottom bolt?
Old Jul 8, 2009 | 9:14 PM
avoyager's Avatar
Default front brake caliper bolts, what is the difference between top and bottom bolt?
I'm changing the front brake pads on my 2003 venture and didn't notice a difference between the top and bottom caliper bolts until I started reassembling.
One bolt has a small rubber/plastic tip; the other doesn't.
The rubber/plastic tipped one is round; the other has flats.
They both seem to fit interchangeably.
Anyone know why they are different and which goes on top?
Thanks,
Chris
Old Jul 10, 2009 | 7:46 PM
avoyager's Avatar
I found out that the caliper bolt (pin) with the small plastic bushing on the tip should be installed on the bottom of the caliper. The other pin, the one w/the flats, should be installed on the top.
Old Aug 4, 2013 | 1:00 PM
darling1s's Avatar
Default caliper bolts
I know this thread is old and you will probably never see this but thanks a million for posting the answer to your own question. I did the same thing (actually replacing the pins because one was sticking). I only have one jack and a couple stands so you just saved me having to try and tear apart the other side to figure out which one goes on the top.
finally03gt
Sep 15, 2014 9:27 AM
factorypilot
Jul 22, 2013 1:45 PM
shawnmid
Aug 4, 2010 1:19 AM
cbr600rrnut
Nov 24, 2008 12:15 PM
waltd140
Aug 30, 2007 11:31 AM
