Knock Sensor?
Old Aug 2, 2009 | 8:33 PM
kermit31's Avatar
Default Knock Sensor?
Does a 92'chevy 1500 with a 5.7 come equipped with a Knock Sensor? If so where would I find it,Its not one on the harmonic balancer area.
Old Aug 2, 2009 | 10:41 PM
lukemoore646's Avatar
yep and its right infront of the starter but before you take it out and drain your antifreeze into your mouth can i ask why you ask?
Old Aug 3, 2009 | 6:02 PM
kermit31's Avatar
i asked because i found a set of wires and plug not hooked to anything the wires are the same color as the wires on my egr solenoid
Old Aug 3, 2009 | 8:26 PM
if the knock sensor isn't hooked up i believe it should set a code, is the service engine soon light on or are there any troubles with the truck?
Old Aug 5, 2009 | 5:34 PM
kermit31's Avatar
there are no codes and the truck seems to run fine sometimes it idels too high
Old Aug 5, 2009 | 8:38 PM
tape em up and dont worry about it, how fast does it idle, and the knock sensor shouldnt affect the idle probably just needs a cleaning
Old Aug 12, 2009 | 9:45 PM
kermit31's Avatar
ok i looked in front of the starter for a knock sensor,and there isnt one.All there is, is a 1/8 or 3/8 plug in the block.Does that mean my engine is not equipped with a knock sensor.Most of the time my engine idles around 1200 to 1300 rpm every now and then it will ease down to 700 or 800 rpms and Ive changed the sensor on top of the intake.
Old Aug 12, 2009 | 9:52 PM
MDTAHOE's Avatar
It maybe on the other side of the engine. The knock sensor only has 1 wire going to it.
Old Aug 15, 2009 | 3:01 AM
kermit31's Avatar
theres a plug in the other side also then theres a sensor rite below the #1 spark plug,rather in that area.
Old Aug 15, 2009 | 9:02 AM
94K1500's Avatar
The knock sensor is a big round one, about 1 1/2", bigger than temp sensors. And it has a round plug in.
