1995 chevy caprice with 5.7 lt1
Old Sep 5, 2009 | 3:41 PM
bbish0p's Avatar
Default 1995 chevy caprice with 5.7 lt1
Does anyone know for sure if the distributor on the 95 chevy caprice with the 5.7 eng would cause the car to shut off without warning?
Old Sep 6, 2009 | 5:14 PM
therewolf's Avatar
Hi bbish0p,
Welcome to the Chevy forums.
The ICM module has a dielectric grease on the bottom. When this dries out, the ICM goes wonky. This causes the ignition to cut out sporadically. Be sure you get an ICM that has a packet of dielectric grease included.(@20$ at any parts store) Replace the ICM. Grease the bottom metal plate well. Check that the rotor and cap are in good condition, with no cracks or carbon tracking.
Peace be with you. Enjoy the rest of the weekend. Best of luck.
Old Sep 6, 2009 | 7:59 PM
bbish0p's Avatar
thanks for the advice. I've already changed the icm but don't think i used any grease when replacing it. If the opti spark was going bad would it have the same effect as listed above?
Old Sep 7, 2009 | 9:13 AM
therewolf's Avatar
Google "opti-spark" there's a world of answers on the internet.(albeit just a series of tubes...)
What's your mileage like, and how's your waterpump? Opti-spark seems prone to waterpump leakage by design. This inherent defect, in combo with high mileage might be the excuse you're looking for to upgrade your drivetrain to a more dependable overall design.
Old Sep 7, 2009 | 12:47 PM
MDTAHOE's Avatar
If you did not put grease on the ICM when you installed it then you need to take it back apart and put it on. No grease on it can cause an array of performance issues.
Old Sep 7, 2009 | 6:37 PM
bbish0p's Avatar
thanks mdtahoe and rivereye, i will do that first. Do either of u know of a good mechanic shop in md?
Old Sep 7, 2009 | 8:54 PM
MDTAHOE's Avatar
I do but I am not sure if I am allowed to post it so I sent you a PM.
Old Nov 7, 2015 | 7:42 PM
lcarter777's Avatar
Default good mechanic in md
Did you ever find a good lt1 mechanic? I'm looking for one myself
canadian33
Sep 28, 2013 6:49 PM
fjbgwks
Jul 28, 2012 6:18 PM
bbish0p
Nov 12, 2009 2:54 PM
bbish0p
Nov 3, 2009 4:04 PM
bbish0p
Sep 3, 2009 5:18 AM
