Ignition module
Old Sep 28, 2009 | 6:54 PM
steamer808's Avatar
Default Ignition module
My 1990 Silverado 4x4 has gone through 3 ignition modules in the last 3 months. The last one only lasted 8 days! I'm putting a liberal coating of dielectric grease on the back side as per instructions. I'm baffled, any advice would be appreciated. Thanks.
Old Sep 28, 2009 | 7:53 PM
therewolf's Avatar
Sounds like your distributor may be getting a electric spike from somewhere.
Hows the big three?(POS,NEG, battery cables and engine to body groundstrap?)
Old Sep 29, 2009 | 6:57 PM
steamer808's Avatar
OK.. disassembled, cleaned and retightened all connections. I got the same advice from a few others as well. Thanks Rivereye.
Old Oct 2, 2009 | 11:06 AM
steamer808's Avatar
Turned out to be the pick-up coil. I'm not 100% sure though... a new pick-up coil got the truck started but the old one tested out to be fine.(???) I didn't change the module this time so maybe it was the p/u coil...I still don't have a good feeling about this.
Old Oct 2, 2009 | 11:37 AM
therewolf's Avatar
You might have to get a little more aggressive than tightening a few connections.
Electricity moves on the outside of the wires. Corroded wires provide high resistance to a 12Volt system.
Consider replacing the cables.
pjm333
Aug 19, 2015 3:40 PM
94burb
Mar 15, 2009 11:40 AM
fjdavid
Jan 26, 2008 2:41 PM
mikeski
Feb 16, 2006 9:41 PM
