wiring diagrams
Old Oct 10, 2009 | 9:18 PM
hunterjo's Avatar
Default wiring diagrams
thanks to everyone who has helped me before on certain problems before. one i have now is i need a wiring diagram of my auto ride system. the area i am concerned with is where the air pump wiring connects to wiring from the vehicle(what i have is a 2001 chevy suburban with auto ride) any help is appreciated.
Old Oct 10, 2009 | 9:32 PM
Mike Sigmond's Avatar
ROTM Coordinator
I see you have posted this question a while back and got no replys. Forgive me for not knowing but what is autoride?
Old Oct 10, 2009 | 9:58 PM
ROTM Coordinator
Ok I looked it up , autoride suspension right? meaning ABS brakes, steering & such?, I will see if I can dig up a diagram for ya.
Old Oct 10, 2009 | 10:08 PM
ROTM Coordinator
I think these are the diagrams for your vehicle. Maybe this will help. Its a 1500 right? or is a 2500 model? & what motor size so I can make sure its the right set of PDFs?
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 10, 2009 | 10:58 PM
Mike: Autoride on the NBS:
Standard on LTZ, and available on half-ton 2LT when equipped with the Vortec 6.0L V8 engine, this suspension automatically varies the shock damping rate on a continual 20-millisecond basis by monitoring road surface, speed, gas and brake pedal, steering angle, and wheel-height conditions to maximize handling and comfort. Also, a rear self-leveling feature helps maintain the rear suspension level with the front during heavy trailering or fully loaded conditions.
Not sure if it was the same on the GMT 800s.
Old Oct 10, 2009 | 11:19 PM
ROTM Coordinator
Thanks! now I get it.
Old Oct 11, 2009 | 12:34 PM
hunterjo's Avatar
yes i ment it has autoride suspension- also it is a 1500 with a 5.3 cid. engine
Old Mar 28, 2010 | 10:05 AM
Brett1's Avatar
I also am looking for wiring schematics for a 2003 suburban autoride system, did anyone have any luck
Old Aug 24, 2011 | 11:12 PM
wv2ak's Avatar
Default Need wiring diagram at the compressor.
We looked at the diagrams here and none of them are back at the auto-ride compressor. We had to replace the compressor and we had to remove the factory harness connector because it was corroded. Now the compressor runs all the time, even with the key off! Can you help us? Thanks.
Ghostracing
Jul 25, 2009 8:25 PM
1990 chevy truck
Apr 21, 2009 7:11 AM
in2pro
Dec 4, 2008 7:32 AM
teddyu
Cobalt
Mar 20, 2008 5:47 AM
bengalwood5
HHR
Nov 29, 2007 10:23 PM
