S-10 & Blazer 1982-2005
o2 help
Old Oct 10, 2009 | 9:36 PM
2doorblazer's Avatar
Default o2 help
hello new here.
I have a 98 2door 2wd blazer (W vin) i got the p0420 code about the o2 is bad. The one b4 the cat. Is there a way to clean to it or should i just get a new one. Cat an muffler are less then a year old. Magna flow cat an muffler. Thanks for any help 2doorblazer
Old Oct 12, 2009 | 8:51 AM
Siliconasp's Avatar
A code P0420 may mean that one or more of the following has happened:
  • Leaded fuel was used where unleaded was called for
  • An oxygen sensor is not reading (functioning) properly
  • The engine coolant temperature sensor is not working properly
  • Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
  • Retarded spark timing
  • The oxygen sensors in front and behind the converter are reporting too similar of readings
98, sensor is 11 years old, I would recommend replacement. cost about $35.00 to $65.00 depending on your location. look online for cheaper deal.
You can pull the O2 sensor and clean it with a cloth to remove carbon buildup and try running again for 1 tank of gas. This can save you some money.
---WARNING---
DO NOT ATTEMPT TO USE ANY TYPE OF SOLVENT ON THE SENSOR ITSELF, AS THIS CAN CAUSE IT TO FAIL. IF THE CARBON BUILDUP IS MAJOR, REPLACE IT.
Old Oct 12, 2009 | 7:18 PM
i took out the front o2 an it looked like a good fireing plug color. i took a small tourch an heated it up an wiped it off with a rag. put it back in an the light came right back on. i cleared the computer buy undoing the neg battery post. also cleaned tps,iac??? the one next to the tps. on the drivers side. thanks 2doorblazer
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
