Help, help, help please
Old Jan 17, 2011 | 8:33 PM
vwwebb's Avatar
Default Help, help, help please
I have 1993 chevy k1500 z71. I need help in identifying this part. It is on my front end it is what the two bolts on the caliper attach to it with. and the upper and lower ball joints go thru it. It is a plate? Well anyways mine is broken one I need one but dont know what it is called. Please help
Old Jan 17, 2011 | 9:09 PM
vwwebb's Avatar
Default ok
Ok so I have been reading and it is my spindle. My truck is a 4 wheel drive truck. Does anyone know where i can find one?
Old Jan 17, 2011 | 9:17 PM
MDTAHOE's Avatar
Professional Mechanic
Dealer, Parts Store (Napa, Autozone, etc...) Junk yard
Old Jan 17, 2011 | 9:35 PM
vwwebb's Avatar
Default so....
So let me ask yall this, (this may show my redneck side a little bit) but here is the issue I had a seized caliper mounting bolt in the spindle when I went to take it out I had to drill it out, so now the upper caliper mount were the bolt would go was striped and a little wider, so I rethreaded it but i had to go i size up, so here is my question, can I just by a bolt long enough to fit in throught the caliper to the new threads on the spindle, or do I have to have the sleeve that the bolt rides in, in the caliper mounting whole.
Old Jan 17, 2011 | 9:43 PM
wmiller1337's Avatar
I'd check out RockAuto.com or AutoPartsWarehouse.com. Those are where I get most of my junk from.
As for the caliper, I am not 100% on this, but I believe caliper bolts are of a special design. Therefore you will need to Helicoil the hole.. but wait till someone else pipes in on that one... Actually, they may sell oversized caliper bolts online somewhere... might try Google-ing that..
Old Jan 17, 2011 | 9:59 PM
RacerX's Avatar
Screw that! You dont want the bolt backing out or jogging in the slot when you need to brake hard. Get a new steering knuckle(spindle) and before you put it in, replace the ball joints and tie rods, its much easier when the spindle isnt in the way.
If you dont want a dealer, look on Ebay or one of your bigger junkyards(U-pull its). LMCtruck.com also
Old Jan 18, 2011 | 1:40 AM
mdseeker's Avatar
If the hole has to be re threaded(if that is it) drill it bigger by a helicoil size chart and use the original bolt.If not possible don't mess around with it buy the new/used spindle its not worth a saftey issue/bin there
Old Jan 18, 2011 | 7:29 PM
vwwebb's Avatar
Default Thanks
O ok thank you to all, I will try to get a helicoil and see if it will work I will keep yall posted.
Old Jan 19, 2011 | 6:07 PM
grumpychevy's Avatar
I agree, go with the Heli-coil and use a factory bolt
Old Jan 23, 2011 | 5:03 PM
vwwebb's Avatar
thanks for everyones help, i was able to rethread it, turns out I had only diproportioned the opening of the hole were the bolt threads into, I tapped it and now the bolts holds steady.
vet67coupe
May 10, 2014 11:33 PM
beezey
Nov 24, 2011 4:01 PM
