Tire size
Old May 14, 2026 | 4:09 PM
urwuis's Avatar
Default Tire size
Good afternoon! I have a 2024 Express and looking to upgrade tires and wheels. I will be leaving the suspension stock. Can I run 265/75/16 without rubbing. 8 inch wheel. TIA!
Old May 14, 2026 | 5:03 PM
Triaged's Avatar
I'm running 265/70R17... So the answer is maybe. They rub the sway bar at full turn and hit the top inside fender well on the front when hitting big bumps off-road. I had to relocate the wheel speed sensor wire to get there. In the back it's the parking brake cables. It's all about offset. Stock 6.5" wide wheels are a bit narrow for a wide tire. 8" wide will cause other clearance issues. Search my username here.
Old May 18, 2026 | 9:38 PM
copper128's Avatar
I’m running 265/60R18 tires on 18x8 wheels. These vans don’t have a lot of room in the wheelwells, so you really have to stay close to the stock 30.5” diameter. Clearance is dependent on your wheel offset, too. I found a decent online visualizer that would show the change from the stock 245/75R16 on stock 16x6.5 wheels to whatever wheel & tire combo you are considering. It’s not a guarantee of fitment, but it’s better than guessing. My tires do rub slightly on rare occasion, usually when going over a bump at or near full lock turning
Old May 28, 2026 | 4:16 AM
Makala's Avatar
It's hard to say; I need more details, but I usually use standard tires.
Old May 30, 2026 | 5:52 AM
Makala's Avatar
Originally Posted by Triaged
I'm running 265/70R17... So the answer is maybe. They rub the sway bar at full turn and hit the top inside fender well on the front when hitting big bumps off-road. I had to relocate the wheel speed sensor wire to get there. In the back it's the parking brake cables. It's all about offset. Stock 6.5" wide wheels are a bit narrow for a wide tire. 8" wide will cause other clearance issues. Search my username here!
Participating in rock-crawling events without proper sticky compounds and flexible carcasses is a guaranteed way to snap an axle or pop a bead. Go through the listings at rim of tire https://level4x4.com/ to discover the best tires and elite crawling accessories for your vehicle. They offer specialized low-pressure options that wrap around obstacles like claws, giving you unmatched traction on steep vertical inclines. It is the premier destination for competitive off-road enthusiasts..
Thanks for sharing!
Old May 30, 2026 | 11:56 PM
loopedr1's Avatar
Talking
I’m running 265/65 18 and they clear no problem. I want to go bigger though
BDO1972
2007 - 2013 (GMT900)
May 5, 2023 10:49 AM
SnlpeR
Sep 24, 2016 11:30 AM
McGirr87
Apr 12, 2011 12:17 AM
JC_07TAHOE
Jan 8, 2008 11:36 AM
