Platform: L-Body
93 lumina water in trunk?
Old Sep 15, 2006 | 4:51 AM
jayno20's Avatar
Default 93 lumina water in trunk?
I just noticed today that there was some water in my trunk.. is this a common problem? any idea's where i should start looking to see where the problem is?
Old Sep 15, 2006 | 11:30 PM
Nomad76lj's Avatar
Default RE: 93 lumina water in trunk?
you will have to look at the trunk seal and also in the little side pockets in the trunk to see if there are any holes there that should get you started.
Old Sep 16, 2006 | 4:20 AM
jayno20's Avatar
seal is good.. and what do u mean side pockets? i looked around the side and there seems to be some sort of caulking there im not sure if its stock or if someone else was trying to stop a leak...
Old Sep 21, 2006 | 5:15 PM
jayno20's Avatar
I sealed up some things i thought might be causing the problem, the car hasnt moved for over a week now and somehow the water is still getting in, its a very minimal amount, but it adds up... i THINK it might be coming from the trunk lid where the "luggage rack" bolts to the lid.. any thoughts on that?
Old Oct 19, 2006 | 8:16 PM
91Euro's Avatar
I have a 91 Euro and i have the same problem. I thought it was coming from the mounting bolts for the spoiler so i siliconed those and it steal leaks. Soo im in th esame boat as you. You may want to try, when you open the trunk there is that trough that goes all the way aroudn where the seal is, towards the front of the car near the bottom of the window there is a body seam where the roof panel meets the rear quarter. Make sure the seal there is good, the filler in mine was cracked so i fixed it, that may be where your leak is coming from.
Old Nov 24, 2006 | 9:35 PM
djdvorak's Avatar
I had the same problem with my 92 Euro. I traced the problem to the welding joints around the outside of the trunk. They had cracked and let in a lot of water any time it rained. I put some silicone caulk on it, and my trunk has been bone dry for 2 years now.
Monty5
Jul 3, 2011 8:44 PM
blueflirt03
Apr 22, 2010 8:10 AM
PAPADUKE512@YAHOO.COM
Apr 6, 2010 7:58 AM
kelseyyystfu
Mar 20, 2009 11:45 AM
kingsman42
Mar 3, 2007 1:21 PM
