2007 tahoe cruise control intermittent
Old Oct 15, 2009 | 11:02 PM
crosskeystv's Avatar
Default 2007 tahoe cruise control intermittent
Normal use of the cruise control is on the steering wheel, 1) turn on the system on the steering wheel, a little yellow light on the wheel indicates it is ready to set(this portion always works fine)
2) next to use the cruise you push the set button, this is where it does not always work sometimes the indicator light on the dash will light and the system will work. Other times it wil not light up or work, or if it was working a bump in the road will sometimes shut it down just like you touched the brake peta
Hopefully someone can help, Thanks, Bill
Old Oct 16, 2009 | 8:09 AM
SabrToothSqrl's Avatar
Default cruise
3year 36,000 much?
Old Oct 16, 2009 | 11:53 AM
Default cruise intermittent
Out of warrenty, 50k miles
Old Oct 17, 2009 | 9:02 PM
HoleInOne's Avatar
I think there is a switch on the brake pedel you can adjust to fix this. Next time it happens put your toe under the brake pedal and pull up to see if it goes away.
Old Nov 17, 2022 | 2:27 AM
XTREME_LOWZ's Avatar
Default Cruise control “fixed” on my 2007 suburban
I’ve been having sporadic issues on my 186k mile Burb. Using my toe I pulled up under my brake pedal and works perfect.
Old Nov 17, 2022 | 6:38 AM
repairman54's Avatar
Brake pedal sensor going bad. Make sure your brake lights are not sticking on.
LarsPA
2007 - 2013 (GMT900)
Aug 14, 2022 6:36 PM
radar1234
Jan 25, 2018 1:31 PM
Testy68
Jun 25, 2017 4:25 PM
jerry.g.coleman
Sep 14, 2014 9:31 PM
K2w
Feb 17, 2010 2:34 PM
