Installing Kenwood 9140 in 09 2500HD, need reverse wire
Old Oct 22, 2009 | 8:06 PM
Padre's Avatar
Default Installing Kenwood 9140 in 09 2500HD, need reverse wire
Hi, I've been searching for about an hour now and can't find this answer.
I am installing a new Kenwood 9149 navigation unit into my 2009 Silverado 2500HD ext cab. I need to find an easily acceptable source for the reverse light signal to trigger the reverse camera. Does anyone know where I can find that? On another forum I found where someone patched into the under hood fuse box backup lights?
Thanks for any help you can give.
Old Oct 22, 2009 | 8:57 PM
therewolf's Avatar
Why can't you just tap the wire going to the backup light?
Old Oct 24, 2009 | 7:31 AM
Go to the BCM under the dash.
Brown connector, Dark blue wire. Depending on the build of the truck, it will be either in pin position 7 or 11.
didn't your integration module provide you with NAV outputs?
barnesam
Dec 31, 2022 2:34 PM
BlackDenali
Jan 9, 2011 7:55 PM
cipher
May 6, 2008 6:40 PM
PaulR
Apr 20, 2008 8:46 AM
