Crazy move - installing reverse parking System
Old May 5, 2008 | 7:29 AM
cipher's Avatar
Default Crazy move - installing reverse parking System
Hello,
I decided to do a crazy step by installing a reverse parking sensors myself on my Tahoe 2006.
But, there is a minor problem that I dont know how cables are running inside the car which I hope someone has this kind of information
HELP!
Old May 5, 2008 | 3:48 PM
treyd45's Avatar
Default RE: Crazy move - installing reverse parking System
Your best bet is just to have a pro do it for you rather then potientially messing up your wiring
Old May 5, 2008 | 4:12 PM
shawnvw's Avatar
Banned
Drill a hole in the floor and make sure you seal it up
Old May 6, 2008 | 6:51 AM
cipher's Avatar
Thank for your reply, the option of using a pro still there, but any one has the electrical guide for Tahoe 2006?
Old May 6, 2008 | 6:40 PM
shawnvw's Avatar
Banned
3wires that you will need for this install.....Lt Green found at the rear lens or in the wiring coming into the vehicle for reverse lights, Black at the same spot for ground, and pink at the ignition switch for ignition if you're going to use a relay to prevent the sensors from falsing when the perimeter lighting comes on
dberladyn
30
Jun 24, 2015 10:28 PM
luckydriver
Jun 3, 2014 9:21 AM
Mille Racer 69
Mar 14, 2011 3:19 PM
chuckster
Nov 18, 2009 7:54 PM
Padre
Oct 24, 2009 7:31 AM
