2003 Suburban Parking Brake Adjustment
Old Nov 2, 2009 | 3:07 PM
rjdjbd's Avatar
Default 2003 Suburban Parking Brake Adjustment
I recently adjusted my parking brake; it helped, but actually needs a little more adjustment. But almost all the adjustment was used up originally at the factory; how can I get more adjustment so my 2003 Suburban doesn't roll back at all in my driveway?
Thank you,
Richard
Old Nov 2, 2009 | 5:35 PM
nauticstar87's Avatar
you may need new parking brake shoes. I had disc brakes all around on my 01 ford and had to get new shoes for the parking brake.
Old Nov 2, 2009 | 8:22 PM
MDTAHOE's Avatar
You need to adjust them inside the drum. Rear rotors have a drum inside for the p-brake. Before you adjust it inside the drum you need to back off that adjustment. Adjust inside the drum first then that one if still needed. It is very common for the shoes to fall apart. Also make sure the actuators inside the drums move freely.
Old Nov 4, 2009 | 3:16 PM
rjdjbd's Avatar
Thanks for the reply. Since my Suburban only has 40k miles on it, I was hoping that the answer wouldn't require pulling the rear rotor...
Richard
Old Dec 27, 2009 | 6:14 PM
rjdjbd's Avatar
Anyone have a step-by-step link or photos? Taking up the slack in the cable helped but didn't last, so I need to pull the rear wheel...
Thank you,
Richard
radetic
Aug 14, 2024 4:24 PM
Manor_Mullet
Mar 26, 2024 8:42 PM
klutz1
Jun 2, 2011 6:17 PM
Schwartz540i
Oct 25, 2010 12:35 PM
klutz1
Sep 30, 2010 5:17 PM
