NP 246 transfer case problems
Old Jan 13, 2010 | 11:55 AM
99ChevyZ71's Avatar
Default NP 246 transfer case problems
I have an oil leak in the front diff, and output shaft play in the NP246 transfer case. When drive selector is in Auto 4WD there is a high pitched grinding sound not present when in 2 HI. It appears a replacement case is just over $1000 and a master rebuild kit about $250. Adding in labor it's probably cheaper to replace entire unit. However I can make it w/o 4WD, but the oil leak in the front is of immediate concern. My auto tech friend informed me that it is a very involved job to replace this simple oil seal. I believe he said it was the inner left stub shaft seal. Any thoughts?
Old Jan 13, 2010 | 12:48 PM
i would look for a wrecked truck with that case in it,or place an add like on craigslist or something like that ...that seal is indeed a pain in the a**
red
Old Aug 30, 2010 | 8:12 AM
99ChevyZ71's Avatar
I replaced the lubricant with AutoTrac II, and the "locking" issue is resolved. The only issue left is a noise when Auto 4WD mode is engaged. This noise does not exist in the 2 Hi mode.
jrsavoie
Feb 28, 2020 4:53 PM
jcwaters1
Oct 24, 2014 10:13 AM
SwitchMIA
Dec 18, 2013 2:09 PM
codypa911
Jul 1, 2013 11:29 AM
jrsavoie
Aug 10, 2010 8:37 PM
