2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2009 LS Keyless Entry won't program
Old Aug 25, 2010 | 1:26 PM
wingherder's Avatar
Default 2009 LS Keyless Entry won't program
My 1st post, please be gentle.......
I recently purchased a used 2009 Impala LS. It has the keyless entry system, and came with one 4 button remote that works fine. The used car dealer gave me another remote similar to mine (not original with my car), except it was the 5 button (remote start) version. My car doesn't have that feature. I attempted to program the other remote following the instructions in the owners manual (using the DIC). These are the same instructions posted in the FAQ at the top of the forum. When I follow the directions (programming mode, holding lock and unlock for 15 seconds, etc), the car "chimes" like it says it should. I re-enter the original remote also (as the directions say you have to). Everything seems to go according to the directions, but yet the 5 button remote does not work. The original 4 button works fine. Is my 5 button remote not compatible? I've noticed that some online vendors for the remotes don't list the '09 Impala as a model. What am I missing?
Old Aug 26, 2010 | 5:29 PM
wingherder's Avatar
bump to top
Old Aug 31, 2010 | 9:46 AM
Official GM Rep
What brand dealership did you go to to get the vehicle or was it strictly a used car dealership?
Jeff Morris, Chevrolet Customer Service
Old Sep 4, 2010 | 6:18 PM
wingherder's Avatar
It was a strictly used car dealership. He deals in a lot of cars he gets from Enterprise Rent-A-Car.
Old Sep 7, 2010 | 9:20 AM
Official GM Rep
I would have to suggest speaking with a local Chevrolet dealership about the fob that you received and see if it in fact does work with the vehicle and if not they can provide a replacement. Going about it in this way ensures that you get a proper replacement key fob and or the proper programming if in fact something did go wrong during the programming process. I hope that helps you. If you have any further questions or encounter any more issues with the vehicle please feel free to contact me through the forum.
Old May 16, 2012 | 3:15 PM
steveo1127's Avatar
Default 2009 mailibu
Having trouble programming fob any ideas
Old May 17, 2012 | 7:59 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> When REMOTE START appears on the (DIC) display, press and hold the reset button for at least one second to scroll through the available settings:
OFF: The remote start feature will be disabled.
ON (default): The remote start feature will be enabled.
To select a setting and move on to the next feature, press the information button while the desired setting is displayed on the DIC.
If you need the remote programmed, please contact your local dealer.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
shoes1
Sonic (Aveo)
18
Nov 17, 2013 11:21 AM
flash1
Jun 19, 2013 3:03 PM
basilkies
Jan 29, 2011 12:42 AM
akareem27
Sep 3, 2009 11:19 AM
