Venture 1997-2005
Platform: U-Body
help
Old Nov 12, 2006 | 12:42 AM
ohioelcamino's Avatar
Default help
i have a friend with a 2001 venture and he says when his headlights come on the turn inddicators have a slight glow and then when you hit the brake pedal the indicators glow a little brighter and if you turn on the turn signals they click loud and fast like you have a burned out bulb but all the bulbs are fine
can someone please help
Old Nov 16, 2006 | 1:16 PM
uncle bill's Avatar
Default RE: help
Could be the flasher.
Old Nov 17, 2006 | 12:52 AM
FoxMulder88's Avatar
Default RE: help
uncle bill's right. most likely the flasher, should be located in fusebox.
Old Jan 4, 2007 | 6:50 PM
leeper's Avatar
Default RE: help
I have a 99 venture and had the same exact problem. Its rear tail light wire housings that plug into the board that all the tail lights are plugged into. Take off the rear tail lights and unplug the wire harness that attaches to the board and I bet the plastic is melted and burnt causing a short or overload.
hope that helps
Old Jan 20, 2014 | 4:39 PM
Tony S45's Avatar
I now have this exact problem on a 2003 Venture. Where is the " ... board that all the tail lights are plugged into."???
Old Jan 21, 2014 | 12:49 PM
200OZ's Avatar
It's right on the back side of the tail lights.
Old Jan 22, 2014 | 6:39 AM
Tony S45's Avatar
Thanks 200OZ!
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
