Chevrolet Sonic
GM Platform: T200, T250, T300
Two questions shift knob, and radio
Old Mar 18, 2007 | 4:45 PM
Sasquach's Avatar
Default Two questions shift ****, and radio
one how to remove the shift **** in an 04 automatic, there is a screw off ring, but the **** wont come off, two i got this car used, and the stock radio needs a code to use after the power is cut off. is there a way to get that code, because the radio wont work without it
Old Mar 19, 2007 | 11:03 PM
pqaveo's Avatar
Default RE: Two questions shift ****, and radio
Unscrew the ring until it comes off. The **** should come off pretty easy after that. I replace mine a while ago, so I don't remember the details, but I know it's not complicated. If you go to the dealership (a decent one), they should be able to get you the code if you can prove that you own the car. It took me almost a month, and trying 3 different dealerships before I found one that could figure it out. Hopefully you will have better luck.
jrsavoie
Jul 4, 2011 6:18 PM
adamant
Feb 15, 2009 8:49 AM
swhitney2003
Sep 10, 2006 6:17 PM
comhunter
Jan 25, 2006 8:58 PM
