Computer, Ignition, & Fuel Systems Talk about the control module, ignition system, fuel system and delivery, customization and more.
Need help for a stalling 94 chevy 6.5L diesel turbo
Old Mar 28, 2007 | 7:39 PM
jojo's Avatar
Default Need help for a stalling 94 chevy 6.5L diesel turbo
I'm working on a 94 chevy silverado 3500HD with a 6.5L diesel turbo engine.It is a cab and chassis with a custombuilt hydraulic flatbed. The engine stalls intermittently and registers a code 35 which is an injection pulse width error. Scanner reads 1.8ms pulse width at an abnormally high idle speed of 1100rpm.While doing a pin voltage testing, I discovered that pin A6 of the ECM was hotwired to ignition. Schematic diagram reveals that there should be no connection to A6. Removing the B+ to pin A6 dropped the rpm to 700 rpm and injector pulse width reads 1.77ms but engine still stalls, specially while accelerating and immediately after service engine soon light comes on with a persistent code 35. Is the connection of A6 to ignition acceptable and valid modification apparently to raise the rpm to boost the hydraulic pressure for the towtruck's flatbed? Has it caused a potential damage to the ECM causing the engine to stall intermittently? Are there otherusualpossibilities causing the engine to stall? Likewise, is there any suggestion for a compatible aftermarket clutch kit. Clutch disc wears prematurely. Your technical advise is greatly appreciated.
Old Aug 5, 2007 | 1:34 PM
juneau84's Avatar
Default RE: Need help for a stalling 94 chevy 6.5L diesel turbo
Has 1 6.5 liter that would run like **** when it got warm, would smoke lots as well, no power and die. Ended up the intake manifold was cracked. Maybe something to check??
Old Aug 30, 2011 | 5:30 PM
Stan Zyla's Avatar
1994 chevy cavalier ign. module location tools needed etc. car won't start.i checked the spark and i'm getting some spark, but i don't it's enough not a big spark. turns over and wants to start but doesn't. had a bad fule pump[ changed that] what else could it be?thank you very much. i can change it if i can locate it and the tools i need. thank you again
Old Sep 15, 2016 | 7:17 PM
ericluck1's Avatar
my 95 6.5 did that and it was the pmd. It's now located on a heat sink .It did fix the stalling issue.
MAST-G
Mar 27, 2013 10:22 AM
Mr1974van
Oct 7, 2012 10:05 AM
jmack91z28
Jan 17, 2012 9:16 AM
UKChevyJules
Sep 23, 2008 5:42 PM
FairTax
Feb 18, 2007 5:01 AM
