TrailBlazer 2002-2009
coolant temperature sensor
Old May 30, 2007 | 10:53 AM
mgunim7631's Avatar
Default coolant temperature sensor
how do i change the coolant temperature sensor on a 2003 Trailblazer. I have already purchased the part but i seem not to find where the sensor is located.
Old May 30, 2007 | 11:26 AM
RonH's Avatar
Default RE: coolant temperature sensor
Which engine?
Old May 31, 2007 | 12:47 PM
mgunim7631's Avatar
Sorry, the engene is a 4.2, 2 wheel drive.
Old May 31, 2007 | 3:54 PM
RonH's Avatar
The sensor is locatedon the driver's side near the front of the engine. It screws into the block behind the alternator. To replace it, you will need to remove the serpentine belt and the alternator and drain the cooling system down to below the level of the sensor. Looks like the electrical connector plugs to the sensor from above -- you will pull the connector straight up to remove it. The connector has two wires, one yellow and the other black. Hopefully, this will help you to locate it.
Good luck
Old Jun 5, 2007 | 12:49 PM
mgunim7631's Avatar
That really helped, thank you so much.
O9aveo5
Sonic (Aveo)
Jun 23, 2015 5:36 PM
penet05
Uplander
Sep 3, 2014 5:01 AM
joshuasoileau
Mar 21, 2012 9:23 PM
SEAN
Sonic (Aveo)
Oct 9, 2010 6:44 PM
mazdacaddi
Feb 16, 2007 5:03 PM
