K5 Blazer 1969-1994
Platform: Truck, GMT 400
Noise when turning sharp!?
Old Jul 18, 2007 | 3:46 PM
DomRulz96021's Avatar
Default Noise when turning sharp!?
Hey,
I just bought a Blazer from my best friend the other day and its got some problems that I need to fix. Yesterday when I was driving it, I noticed that everytime I turn sharp it makes a creaking noise. I thought it was the swing arms, but I'm not that "car savvy". My buddy said I should check my bushings or whatever. Seeing as I've never had to work on my own car before, I have no clue where they are located. If you guys could help me out, that would be great! Thanks.
Old Aug 7, 2007 | 11:27 PM
BigBoom360ci's Avatar
Default RE: Noise when turning sharp!?
There is a difference between a creaking noise from metal to metal contact & a bushing creaking so listen closely.
Old Aug 10, 2007 | 6:17 PM
kcb37's Avatar
The bushings are just rubber spacers. You should have four, on the a arms. (connect the hubs to the frame). The shocks, the sway bar, I don't remeber if the torque arms have them or not. Things like that. I may help to have someone on the bumper bouncing while you look at it. That may be enough to hear it.
ld9z24
Apr 25, 2019 1:34 PM
07Chevyboy
Mar 30, 2015 9:31 PM
leethedeuce
May 16, 2014 7:08 PM
AKBOB1953
Dec 29, 2007 12:22 AM
kreal
May 26, 2007 7:16 PM
