S-10 & Blazer 1982-2005
2001 door panel removal
Old Aug 13, 2007 | 8:12 PM
mcyclye's Avatar
Default 2001 door panel removal
I'm trying to replace the outside door handle on the driver side. But the door panel is in my way. I removed the screw behind the inside handle and popped out the window and door lock panel. My Chilton manual shows a pop out panel in the door pull area that has a couple of bolts behind it. My truck doesn't have this panel and bolts. Is there something else I need to remove or do I need a special tool to pop the clips? Any help would be appreciated. My truck is a 2001 S10 crew cab.
Old Aug 19, 2007 | 5:52 PM
kcb37's Avatar
Default RE: 2001 door panel removal
So long as you have all the screws out the panel has clips that you can get a 5 dollar screwdriver like tool from a parts store to pop the door panel off with.
winty03
Apr 21, 2007 1:57 AM
Bentley
Jan 26, 2007 1:52 AM
Bentley
Jan 24, 2007 7:46 PM
Tomahawk06
Dec 6, 2006 2:23 PM
LeoDuffrin
Apr 27, 2006 10:43 PM
