04 C\K - Temperature Valve Actuator Replacement
Old Jan 17, 2012 | 3:40 PM
  #41
Toyo5spd's Avatar
Default 08 Silverado Digital Dual HVAC Issue
Hey Shawnvw,
I see you are the go to guy so far on this topic. I have a 08 Silverado with a digital dual climate control. The drivers side blows ice cold air and the passenger side blows hot air. I was able to get it hooked up to a ALLDATA REPAIR computer and get the code that are wrong, but its like reading a foreign language to figure out what is wrong. Any advice/help you could send my way would be great.
Thanks
Old Jul 8, 2012 | 5:14 PM
  #42
s_h_e_l_i_a's Avatar
Default a/c blowing warm on passenger side
What problem is going on if the a/c was working on fine then the blower motor started acted up and I replaced it. But right before i replaced the blower motor the driver side started blowing warm. Any ideas I have an 03' impala.
Old Nov 29, 2012 | 2:09 PM
  #43
jamesdal7's Avatar
Default Picture of actuator
Here is a picture, make sure you get the right one....
Attached Thumbnails 04 C\K - Temperature Valve Actuator Replacement-actator2.jpg
Old Jul 26, 2013 | 11:42 AM
  #44
housetiger77's Avatar
Originally Posted by shawnvw
Actuator Recalibration
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
  1. Place the ignition switch to the OFF position.
  2. Disconnect the scan tool.
  3. Install the HVAC control module.
  4. Connect all previously disconnected components.
  5. Start the vehicle.
  6. Wait 40 seconds for the HVAC control module to self-calibrate.
  7. Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Preferred Method (w/ Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch in the OFF position.
  3. Install the HVAC actuator.
  6. With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch to the OFF position.
  5. Remove the HVAC/ECAS fuse for a minimum of 10 seconds.
  6. Install the HVAC/ECAS fuse.
  7. Start the vehicle.
  8. Wait 40 seconds for the HVAC control module to self-calibrate.
  9. Verify that no DTCs have set as current DTCs.
What is the HVAC control module? Are you talking about the actuator?
Old Dec 22, 2013 | 3:38 PM
  #45
kaps's Avatar
I know this is a few months old but there are instructions for the control module at the top and instructions for the actuator at the bottom.
I also wanted to say thanks for the instructions and to add I picked up a AC Delco replacement actuator from Rockauto.com for $40 shipped, beats the dealer and gmpartsdirect.com prices.
Thanks again
Barry A. Waters
Aug 17, 2019 11:12 AM
gharph
Oct 22, 2014 10:19 AM
TahoeMatt
Feb 28, 2013 8:13 PM
skategranger
Feb 18, 2013 2:38 PM
rich1911
May 12, 2010 6:52 AM
