Notices
Sponsored by: DashLynx
1994 Chevy startup problems
Old September 25th, 2013, 9:42 AM
Meyman33's Avatar
Default 1994 Chevy startup problems
Hi i have a 1994 chevy 1500 350, in the morning and after about an hour of not starting my truck, it will start for about a second or so and then shut off, and no matter how long i crank it it will not start up again unless i pull the key out and put it back in. Then it still does the same thing, THE ONLY WAY i can get it to stay running is hit the fuel line with a pipe wrench a couple of times, i just put a new fuel pressure regulator in last night and it ran fine until this morning, and it seems to have had no effect. IT does have a lot of lights, around 50 or so and also a remote start security system, i have a fuel filter to put on but at he moment ive pretty much given up, any help from you guys would be greatly appreciated!! Also has a throttle body spacer.
Old September 25th, 2013, 10:40 AM
Fishinfooleric10@aol.com's Avatar
I would check your spider injection and or fuel pump, I just had to do a fuel pump on my buddy's 93 chevy for those same kind of symptoms.
Old September 25th, 2013, 12:26 PM
Meyman33's Avatar
Thanks for replying, ive been told now it is probably the fuel pump, after about an hour of driving the thing will just completely quit, not even sputter, but all i still have to do is hit the ****ing fuel line and she goes! So ill try the pump and see.
Old September 26th, 2013, 12:19 PM
Meyman33's Avatar
Heres an update, i did find a pretty good sized crack in my fuel line, i taped it up for now and it seemed to run better, but still shut off. Just wondering if anybody knows any sensor that would shut the engine off?? It doesnt even sputter when it shuts off either. Thanks!
Old October 1st, 2013, 11:17 PM
silverado28's Avatar
had the same problem with mine. it was the fuel pump, if u replace fuel pump make sure and replace fuel filter to. but if you have a crack it could be sucking air instead of fuel and starving it. id get the crack fixed no matter what.
Old October 9th, 2013, 11:42 AM
Meyman33's Avatar
Ive been told the pump and the filter, i have a filter to put on but just recently my alternator went out and i have about 8 offroad lights to power up and about 50 running lights among my normal lights for driving, id like to get that fixed first, anybody know what amp alternator i should use? I have the main battery up front connected to a deep cycle in the bed. I was alos told my security system could be turnign the truck off. thats the update as of now thanks guys!!
Old October 10th, 2013, 12:29 AM
With all those lights, I would get at least a 120 amp alternator.
hills_willie
August 7th, 2014 8:02 AM
Magnus Sweden
February 20th, 2011 10:29 AM
bassmanatcs
February 8th, 2011 10:09 AM
DimebagDarrell
June 13th, 2006 11:19 PM
Quick Reply: 1994 Chevy startup problems
