Notices
Sponsored by: DashLynx
1988 454 sluggish question
Old May 17th, 2012, 1:57 PM
wrightml's Avatar
Default 1988 454 sluggish question
I have a k3500 454 and it is running pretty bad (just bought it three weeks ago) At first it started idling high and hesitating so I put a new TPI on it and set it @.637 volts per instructions that fixed the first problem.
Now it seems the hesitation is at 1/4 to 1/2 throttle position.
Any help would be appreciated
Thanks
Mark L.<O</O
Old May 18th, 2012, 9:08 AM
Former Sponsor
johntaps's Avatar
As you mentioned that engine hesitate at 1/4 and 1/2 throttle position then only thing you have to check is oxygen sensor.
Old May 18th, 2012, 10:18 AM
wrightml's Avatar
Thank you I will replace it over the weekend.
And will update my progress.
Mark
Old May 18th, 2012, 8:21 PM
RacerX's Avatar
What name brand was the Throttle sensor? Some of the name brands are wack right out of the box. TPS may be bad and have a signal range fault which is why you are stumbling on mid-throttle.
And besides you werent sure the high idle was the throttle position problem versus as dirty throttle body or stuck/bad idle speed control solenoid. Dont waste money buying parts you dont need, just give it to me instead.
Fuzy
March 21st, 2014 12:12 PM
core shift lsx 454
November 18th, 2012 3:35 PM
heavychevy511
October 31st, 2012 8:43 PM
woodstockaz
August 15th, 2010 4:08 PM
SILVERAD01
April 23rd, 2010 9:48 PM
Quick Reply: 1988 454 sluggish question
