Notices
Sponsored by: DashLynx
94 Tachometer Install
Old April 24th, 2013, 7:41 PM
94ColoradoSilverado's Avatar
Default 94 Tachometer Install
My temp gauge quit working so I got a sending unit. That didn't fix it so I went to a wrecking yard where I might be able to find an instrument cluster.
I found one with a tachometer. Mine didn't come with a tach. I was wondering if it was possible to replace this cluster with tach, with my no tach cluster.
Does anybody know if I have to wire for the tach or is it just not worth the trouble. There are several in the yard with no tach. Before I buy one I thought I would check here first. I pull a boat so a tach would be really helpful.
Thanks for the help
Tony
Old April 24th, 2013, 10:22 PM
hicksvilleshick's Avatar
Thanks for the help
Tony
I'm not sure if the wiring harness in yours would have wires for a tach, I can't imagine it would be hard to run one tho. I just put a aftermarket one in recycled from a my old old suburban... I just hooked into the marked tach lead off the distributor and ran it in the cab.
Old April 26th, 2013, 10:43 AM
Default Tacho
I went ahead and bought the cluster with a tach. I found the best one I could and this one had only 99k miles on it. The lenz was all scratched up though so I used my original lenz but I had to drill a hole in it to accommodate for the trip meter ****. In this picture you can see the hole where the **** came through for the non tach cluster.
Believe it or not, It plugged into place and everything worked. Even all the lights worked. The only thing in question is the tach indicating a very low RPM when idling in drive. It reads 200 RPM but I know it's more than that. Could it be a tired tach?
In this picture, the engine is off.
Thanks again for the help.
Tony
dmoore
December 7th, 2011 9:02 PM
fdxdoeboy
November 16th, 2007 11:12 PM
shulamite
Express & G-Series Vans
November 12th, 2007 3:41 AM
Rivernut
November 1st, 2007 7:14 AM
96beretta142k
September 27th, 2006 3:20 PM
Quick Reply: 94 Tachometer Install
