Notices
Sponsored by: DashLynx
auxillary power outlet
Old February 3rd, 2009, 2:20 PM
ChevyMan74's Avatar
Default auxillary power outlet
I am looking for the fuse for aux. power outlet on my 2003 silverado 2500,its the outlet on dash on drivers side,checked underhood fuse box and the drivers side fuse box to no avail,had a light plugged into it and it just stopped working,any ideas or helpful hints would be greatly appreciated.
Old February 4th, 2009, 2:29 PM
therewolf's Avatar
Don't know if this helps, but my 04-2500 has 2 side by side, under the climate control. IF yours is the same, and the passenger side one works, I would say check the socket, make sure power and ground are both tight.
Old February 5th, 2009, 8:01 AM
ChevyMan74's Avatar
Default Thanx
At this point any suggestions might be the answer,I can't believe GM doesn't mark this in the owners manual,I have worked on GM products all my life so I feel kinda dumb not having diagnosed this yet,I will check that outlet itself next,THANX Rivereye for you're help!
Old August 15th, 2011, 10:17 AM
Jimdsi's Avatar
After using a power inverter, I lost power at both my rear and front auxillary power sockets. At the time, I assumed I had taken out the fuses but that was not the case. Something at the rear of the sockets themselves opened and prevented power from getting thru. I don't know it the sockets have built-in fuses, or if they just couldn't handle the load, but replacing the sockets fixed the problem.
the Wizard
Express & G-Series Vans
September 26th, 2020 5:20 PM
Dopeoperator
September 29th, 2010 9:49 PM
Otown
Equinox
September 17th, 2010 1:54 PM
Nasute
December 9th, 2008 6:29 AM
Louis88vette
August 29th, 2007 11:52 PM
Quick Reply: auxillary power outlet
