Blowing fuses and not running!
Old Jun 7, 2010 | 6:03 PM
  #11
ds76's Avatar
Just over 232,000
Old Jun 7, 2010 | 8:54 PM
  #12
MDTAHOE's Avatar
Professional Mechanic
Originally Posted by ds76
Just over 232,000
You got very lucky, if that is the first pump. What brand pump did you get? Did it come with a new connector?
Old Jun 7, 2010 | 10:44 PM
  #13
ds76's Avatar
It was an Airtex brand pump. It did come with a different connector and an adapter that I had to splice to the harness. I probably should have bought Delco, but this one was a hundred dollars less and has the same warranty. I may live to regret it.
Old Jun 8, 2010 | 6:54 AM
  #14
MDTAHOE's Avatar
I have not heard anything good about a Airtex pump. If you have to pull the tank again is the $100.00 worth it?
Old Jun 8, 2010 | 7:26 AM
  #15
ds76's Avatar
You're most likely right about the pump and looking back, I probably should have spent the extra money. But at least now that I've pulled the tank once, it won't be nearly as hard the second time. I think I'll keep the tank just a quarter full for a while, just in case.
David
Old Jun 8, 2010 | 11:32 AM
  #16
LARIDERS's Avatar
A pump can burn up and over heat from having low amounts of gas in the tank. the pump uses the cool gas in the tank to help keep it from getting to hot.
Old Jun 9, 2010 | 6:48 AM
  #17
ds76's Avatar
Okay, I'll bring it up to half a tank.
flukester
Aug 31, 2012 4:38 PM
flmax40
Jun 11, 2011 11:54 AM
netty
Oct 23, 2009 12:04 AM
mychevyvan
Oct 23, 2006 1:02 PM
