Notices
Sponsored by: DashLynx
check gauges light wont cut off
Old June 14th, 2010, 9:43 PM
isrblue's Avatar
Default check gauges light wont cut off
my 96 1500 has had the check gauges light on since i bought it 3 months ago.my buddy hooked up his scanner tool and everything came back good. I have good oil pressure plenty of gas, a brand new battery, and its not overheating what else could i be missing that would cause this light to stay on. Its been driving me crazy trying to figure this out. any feedback would be appreciated.
Old June 15th, 2010, 6:33 AM
maxxman04's Avatar
what codes did your buddy's scanner pull? if the light is on, there's a reason for it.
Old June 15th, 2010, 7:58 AM
isrblue's Avatar
Well there weren't any codes. It's not the same as the 'check engine light its another one that says check gauges' light that won't turn off. I heard it turns on if you're low on gas, overheating, etc
Old June 15th, 2010, 8:16 AM
maxxman04's Avatar
ah yes, my bad. read your post wrong. which gauge isn't working?
Old June 15th, 2010, 8:45 AM
isrblue's Avatar
Well that's what I can't figure out . I've checked everything that has a gauge and everything seems fine
Old June 15th, 2010, 10:13 AM
maxxman04's Avatar
ok, so all the gauges appear to be reading normal and good? low voltage reading, high temp, low or no oil pressure. these all will set off the check gauge. it supposed to go out when all is well. if it's not, and all is good, you may want a shop to look at. might be ecm issue.
Old June 15th, 2010, 5:29 PM
isrblue's Avatar
I just rechecked everything again and still good. And I just replaced the ecm a month ago for different reason but that light is still on my buddy suggested trying a thicker oil what do yall think
Old June 15th, 2010, 6:16 PM
Professional Mechanic
MDTAHOE's Avatar
Do not use thicker oil. If the pressure gauge reads good then that is not why it is on. Maybe the cluster is bad.
Old June 15th, 2010, 6:24 PM
isrblue's Avatar
Ok how would I be able to check if the cluster is bad?
my99suburban
April 9th, 2014 7:47 PM
o.valdez
December 17th, 2011 10:46 PM
bossman696
July 19th, 2010 11:17 AM
todds96cav
October 28th, 2009 11:11 AM
gdanquah
August 14th, 2006 8:59 PM
Quick Reply: check gauges light wont cut off
