Clock resets to zero, iffy start
I just had the power steering fluid resrvoir replaced on my 2005 Silverado and now every time I start it up, the clock resets to zero, and it almost didn't start a few times. Kind of a clicking sound, but not really like a dead battery. Wonder if they disconnected the battery in recent work done and could be loose??? Also read it could be a fuse, or a bad ground? Thanks!
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> intrepid,
It sounds like it may be related to the battery. I recommend having them look at it again, if it worked before, it may be related to the repair work performed.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
Sounds like a loose battery end had the same issues in a grand Cherokee, I replaced the ends and it solved the issues but like Louis said they should fix it if the had to take it apart the do it
tomjonesrocks
June 17th, 2014 6:04 PM
racerx55
Silverado & Fullsize Pick-ups
December 28th, 2009 5:09 AM
TriVHo
February 18th, 2008 4:14 PM
