Harness Question w/Pic: 1995 K2500
Old Apr 30, 2013 | 11:10 PM
rook13pdx's Avatar
Default Harness Question w/Pic: 1995 K2500
Top: generic Chevrolet harness to mate to the HU, it's the maile to the female vehicle harness. Note the bottom four wires: green, purple. They're supposed to be for the rear speakers.
Bottom: Actual harness from K2500 that above plugs into (I cut one out at a junk yard, made sure later it was exactly like mine). Note the top left four wires - they match the rear when plugged in - *** and the additional two green wires *** is this single set for both rear passenger doors?
When I hooked this up, the "rear" wires on the generic harness only powered the 4" x 10 just over the barn doors, not the actual rear passenger doors. Do the two *extra* two green wires actually split somewhere down the harness and power both of the back passenger doors???
I would rather not power the 4" x 10"s at all, and just all four door speakers (and a friggin great sub!). But, can't figure it out, WTF... I guess I could just run my own wires, but it would be nice to handle it all at the HU.
Any info?
Old Jun 9, 2013 | 11:09 PM
partyd's Avatar
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown
austink123
Jan 24, 2015 1:04 PM
CleverCobra
Mar 31, 2014 6:22 PM
phricard
Apr 15, 2013 1:03 PM
jrsavoie
Feb 24, 2010 2:38 PM
taybrady
May 22, 2009 10:48 AM
