Harness Question w/Pic: 1995 K2500
Top: generic Chevrolet harness to mate to the HU, it's the maile to the female vehicle harness. Note the bottom four wires: green, purple. They're supposed to be for the rear speakers.
Bottom: Actual harness from K2500 that above plugs into (I cut one out at a junk yard, made sure later it was exactly like mine). Note the top left four wires - they match the rear when plugged in - *** and the additional two green wires *** is this single set for both rear passenger doors?
When I hooked this up, the "rear" wires on the generic harness only powered the 4" x 10 just over the barn doors, not the actual rear passenger doors. Do the two *extra* two green wires actually split somewhere down the harness and power both of the back passenger doors???
I would rather not power the 4" x 10"s at all, and just all four door speakers (and a friggin great sub!). But, can't figure it out, WTF... I guess I could just run my own wires, but it would be nice to handle it all at the HU.
Any info?
Any info?
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown
F Not Used
austink123
Jan 24, 2015 1:04 PM
CleverCobra
Mar 31, 2014 6:22 PM
phricard
Apr 15, 2013 1:03 PM
jrsavoie
Feb 24, 2010 2:38 PM
taybrady
May 22, 2009 10:48 AM
