Old Jul 29, 2015, 6:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Lowering my 1989 Chevy C1500
Old Dec 28, 2009 | 5:05 PM
weakbutstrong's Avatar
Default Lowering my 1989 Chevy C1500
I need help knowing what I should do to lower my 1989 C1500 Extended Cab 2WD. I'd like to achieve a 2" Front 4" Rear drop. Because I still use my truck to haul on ocassion--I need to work with something that doesn't completely abandon my ability to use the truck under some weighted loads.
I've been doing a lot of research and have found that I can go spring/shock combo or a spindle for the front. What are the pros and cons of each?
Also, for the rear--I've looked into the Firestone airshock system offerred through BellTech, shackle/hanger combos and spring/shock combos...
I have no idea what the most effective options are here.
Ideas or opinions?
Old Dec 29, 2009 | 2:20 AM
Blasterhappy71's Avatar
If you have the bucks a drop spindle is the way to go for the front. The rear is a toss up because any way you go your going to lose some of your ride by stiffening up the rear with Air Shock or bag systems. Just stay away from blocking the rearend if you can. Good Luck!
Old Dec 29, 2009 | 10:33 AM
BlasterHappy71--Thanks for the input. I understand for the rear that there's a way to use a shackle and hanger to modify the rear leaf's position to get a 4" drop. If I did this, would I have to modify anything else in the rear-end to accomodate this change?
Old Dec 29, 2009 | 7:30 PM
4 inches is about the max you can go without having to deal with bump stops and drive shaft binding. You should be ok.
Old Jul 25, 2010 | 12:01 PM
1sweetride's Avatar
Default I just got a 1500 yesterday and am interested in dropping it also
I would like to kow what route to go and what results you get.
Old Aug 16, 2010 | 7:13 AM
gaush007's Avatar
Hey friend you can use the below link to get more information on this http://www.pickuptrucks.com/html/techtip/lower3.html
Old Aug 18, 2010 | 12:40 AM
1sweetride's Avatar
Default I saw on Truck U what I am going to do
just need funds to get the job rolling.
http://www.airliftcompany.com/application_guide.php
air ride! = - )
Old May 15, 2013 | 8:38 AM
lashrimper's Avatar
New User
Awaiting E-mail Confirmation
Default 1989 chevy pickup
what is the average retail on a clean 1989 c/1500
Old May 22, 2013 | 12:50 AM
jnsn's Avatar
Here's an easy way to get a two inch drop on the rear end which will level the Silverado (it is high in back when not loaded.) I talked with Bell tech advisor who told me by using their lowering shackles and taking out the over load spring, I could get two or more inch drop. Since I do not use the truck for hauling, the overload isn't needed. I had a mechanic do it and it rides okay with no noticeable difference. j. jnsn
Kass
Feb 16, 2014 2:16 PM
mattintc
Aug 14, 2012 11:36 AM
jaguar11
May 28, 2012 12:04 AM
bumblebee2012
Aug 19, 2011 3:58 PM
Hardin Thicke
Aug 8, 2009 10:06 PM
