Notices
Sponsored by: DashLynx
Replacing 4L60e; now its stuck to the engine
Old April 17th, 2011, 6:59 PM
apgambino's Avatar
Lightbulb Replacing 4L60e; now its stuck to the engine
hi all, I decided that my best bet in fixing my 95 1500 with the bad tranny was to just replace it. i bought a recently rebuilt model off craigslist for 300 bucks and set off the do the swap.
I bought the haynes manual and followed all the instructions. it is pretty straight forward. I am at point where I just finished unbolting the old unit from the engine. my problem is that it is stuck to the engine. I have tried jacking the transmission up a bit, and then letting it down to the point where it is hanging there. I have also whacked at it with a 4lb hammer (busted the tailshaft of the old one ) but to no avail.
Anyone have an ideas? I have an air chisel but I think that would jack up the engine itself.
Let me know what you all think, i'm open to anything since I'm stumped.
Old April 17th, 2011, 9:04 PM
Mille Racer 69's Avatar
the stock stuff that is on there is a pain.
use a heat gun.
good luck
Old April 19th, 2011, 1:21 PM
apgambino's Avatar
that sounds like it could help; any particular spot to focus on?
Old April 24th, 2011, 10:39 PM
tinbender59's Avatar
you are in luck! yesterday i pulled the motor out of mine, so here we go: there are 6 bolts that hold the trans to the motor, ( 15mm or 9/16 heads) if two were 13mm you are not done, go after the rest of them. then there are 6 15mm headed bolts that hold the flywheel cover on plus 2 bolts on the struts - 4X4, the 2WD has 5 or 6 10mm headed bolts. that should be it
Old April 24th, 2011, 11:27 PM
not really sure, I just used it all around the area where they connect together.
Old April 27th, 2011, 6:00 PM
astrofast4.3's Avatar
Just for kicks, did you remove the torque convertor bolts??? That trans should just walk right outta there
technicauto
January 23rd, 2017 10:15 AM
97chevyrichie
May 13th, 2014 9:59 AM
abqgolfer
August 27th, 2011 11:30 PM
BlackDenali
January 17th, 2008 10:01 AM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: Replacing 4L60e; now its stuck to the engine
