Notices
Sponsored by: DashLynx
rubbing noise when turning left
Old August 18th, 2011, 8:19 AM
Bigdaddy95's Avatar
Default rubbing noise when turning left
Greetings !
I have a 2004 silverado 1500 ext. cab./ 85k
When turning left, at a slow speed, I hear a rubbing noise, (rubber?) and feel a slight vibration in the steering wheel.
no clunks or bangs like I've read about.
Steers fine, back roads, and hwy.
P/S fluid is full.....no leaks underneath.
serpentine belt is tight.
Can anyone out there guide me in the right direction please ?
Would like to do this repair myself.
Thank-you in advance.
Bigdaddy
Old August 21st, 2011, 1:49 AM
usmarine0905's Avatar
Could your tires be rubbing agaist the rubber spash sheild..??
Old August 24th, 2011, 1:23 PM
Bigdaddy95's Avatar
Default reply
Checked the splash sheilds..( thanks usmarine0905 )
Nothing rubbing there.
I will check underneath again.
Thanks, Bigdaddy
Old August 24th, 2011, 2:13 PM
slw210's Avatar
Wheel bearing.
Old August 24th, 2011, 3:20 PM
kevinkpk's Avatar
Originally Posted by slw210
Wheel bearing.
Could be. I'd suggest jack it up, and pull on the wheel to feel for any play in it.
Old August 29th, 2011, 12:58 PM
Bigdaddy95's Avatar
checked wheel bearing,No play in wheel.
Sounds like rubber against metal.
actually sounds like it's coming from the firewall
Old August 29th, 2011, 2:22 PM
kevinkpk's Avatar
Could it be the blower motor, since you say sounds like it is comming from the firewall?
Old August 31st, 2011, 6:09 AM
Bigdaddy95's Avatar
don't think it's a blower motor.
feels like it's in steering column.
I read there's an intermediate steering shaft.
Anyone have any insight??
Thanks !
Bigdaddy
Old September 1st, 2011, 12:05 PM
GM Fixer's Avatar
sounds like the seal that the steering shaft goes through at the firewall is dry. Spray some silicone on the seal. My truck does the same thing. it is a squeel/ moan sound.
Old September 2nd, 2011, 6:33 AM
Bigdaddy95's Avatar
Yes.....that is the sound !!
I will spray it after work.
Stay tuned !
Thank-you.
Bigdaddy
Quick Reply: rubbing noise when turning left
