Bottom radeator hose blew& power steering pump line also. Why?
Old Dec 27, 2022 | 8:00 PM
98Chevyc1500's Avatar
Default Bottom radeator hose blew& power steering pump line also. Why?
Yes last night I got in my truck to go out. So I did my normal routine I checked the oil was a little low so I added oil then I checked the water was a little low added water to the overflow tank. Then I started the truck let it get to operating temperature and niago friends house fostering in front of my friend's house it was sitting in idling and the next thing I know I see Steam and steam everywhere so open up the hood and the bottom radiator hose is popped off and the power steering hose popped off right at the compressed fitting at the end of it and have no idea why this all happened now I got power steering fluid all inside the engine bay and don't know if this is part of maybe something bigger or if just the heat from the bottom radiator hose made that fitting pop off I don't know any suggestions or any ideas anybody
Old Dec 28, 2022 | 11:14 PM
oilcanhenry's Avatar
Doesn't matter why. You just have to repair it. Look on it this way: You have a coolant change and a power steering oil change all at the same time. P-S and axle oils are often ignored. Even antifreeze changes are ignored, as well. You can use "Simple Green" to get the oil off at a high-pressure auto-wash on detergent wash. Spray it down at 100 percentage, before, to allow it to soak into the oil.
bob Torst
Apr 27, 2020 11:05 AM
Nebulation
Jan 31, 2014 7:35 PM
gray gables
Dec 2, 2013 3:32 PM
jdog0411
Feb 11, 2013 9:53 PM
robbiestuff
Jul 17, 2006 11:41 AM
