Question about power steering leak
Old Apr 27, 2020 | 8:50 AM
bob Torst's Avatar
Default Question about power steering leak
I have an 07 tahoe that is leaking power steering fluid from what seems to be the bottom of the pump, I cant tell if it is the larger return hose or the high pressure hose. I seems like the larger return hose(If I am saying that right). The steering seem fine and the pump isnt making any noises. Could this be a hose issue, o rings ect. Is there a better way to tell if the leak is a cause of the pump or the hose?
Old Apr 27, 2020 | 10:57 AM
Welcome to the forum. Clean everything as best as possible. Start the engine and see if you can tell where it is coming from.
Old Apr 27, 2020 | 11:05 AM
Cusser's Avatar
How often are you needing to add power steering fluid? If less than every 2 months or so, maybe just op off as necessary.
Dave001
Sep 14, 2017 5:12 PM
doug1962
1988 - 1998 (GMT400)
Sep 30, 2016 9:40 PM
Nebulation
Jan 31, 2014 7:35 PM
jdog0411
Feb 11, 2013 9:53 PM
tahoe99
Aug 7, 2007 11:04 AM
