need help
need help
I have a 95 chevy silverado 8 cyl 4x4 that is acting up. When I press on the gas pedal while driving the truck makes a jerking motion acting like it is going to stall. I have replaced the air and gas filter but it is still doing it. Does anyone have any other suggestions that I can try. Thanks.
need help
I have a 97 silverado that makes a slipping/grinding noise at intersections when the tires slip on the snow. When I let off the gas it catches and is fine. It only does this in 2wd. Any idea what i'm dealing with? Differential? Transfer case? Cost? Thanks for your help
Have you checked for varnish build up in the air valve? I had a 97 and a 2000 Chev truck and they built up varnish, the air valve (controlled by the accelerator pedal) would stick and not want to change position. Then when you pushed hard enough on the pedal to move the air valve, the truck would jump. Remove the big air hose from the cleaner to the valve and clean with injector/carb cleaner and paint brush/toothbrush.
NateP1134
Engine Building & Overhauling
September 24th, 2015 12:05 AM
be_Martinezr
October 6th, 2014 10:19 AM
1stTahoe
April 19th, 2012 9:44 PM
upzaw2000
HHR
December 31st, 2006 9:36 PM
