Notices
Sponsored by: DashLynx
Old August 4th, 2015, 3:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
will not turnover reset security system
Old August 11th, 2012, 4:35 PM
nbmech's Avatar
Default will not turnover reset security system
Hello,
My 08 silverado has a short somewhere because yesterday the day runnning lights were on and the washer fluid pump was running. I disconnected the pump and removed the fuse for the lights. I recharged the battery and it would not turn over. The battery was tested and only had 6 volts with no load after 6 hours on the charger. New battery and it still wont turnover no clicking. All electronics work, just no clicking. Someone mentioned possibly the theft system may need to be reset. How do I do this?
Old August 11th, 2012, 5:33 PM
kevinkpk's Avatar
Check the anti theft fuse. I won't crank if that circuit is dead.
Old August 11th, 2012, 5:58 PM
nbmech's Avatar
I checked and still nothing the keyless fob works
Old August 11th, 2012, 6:22 PM
kevinkpk's Avatar
Try putting the shifter in nuetral, give that a shot.
Old August 11th, 2012, 6:26 PM
nbmech's Avatar
Still the same, all electronics inside work ,silence from the engine. The message center shows HOOD OPEN and SERVICE FOUR WHEEL DRIVE
Old August 11th, 2012, 7:45 PM
kevinkpk's Avatar
Might be the key fob keeping you locked out.
Old August 11th, 2012, 7:57 PM
nbmech's Avatar
I tried my spare key also. I have noticed that things that need the key in the on position are staying on( day running lights, washer pump, and the radio stays on after the door is open) possibly the ignition could be bad????
Old August 14th, 2012, 2:23 PM
Official GM Rep
Originally Posted by nbmech
Hello,
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Would you please PM me the last 8-digits of your VIN, so I may look into this further for you?
Louis
GM Customer Service
Old August 24th, 2012, 7:22 AM
nbmech's Avatar
UPDATE...
It turns out the body control module, transmission control module, transfer case control module and engine control module were all bad. After talking with a neighbor he remembered hearing a close lightning strike. I guess that could have possibly caused the issue. The dealer is asking GM to assist with the repair cost.
Thanks for your help.
<!-- / message -->
Dallas Prothro
December 26th, 2019 5:12 PM
njdpb22
K5 Blazer
September 2nd, 2008 6:09 PM
DaWuuf
October 21st, 2007 9:06 PM
chevy3quarta
October 7th, 2007 4:50 PM
Quick Reply: will not turnover reset security system
