2001 Tahoe rear AC system problems
Old July 18th, 2008, 5:07 PM
TexasLonghorn1971's Avatar
Default 2001 Tahoe rear AC system problems
There is some sort of short in the rear AC system in my Tahoe. Once in awhile it works briefly after hitting a bump, but for the most part, it does not. Any ideas on how to fix this? The front AC works fine...
Old July 18th, 2008, 10:08 PM
Default RE: 2001 Tahoe rear AC system problems
Welcome to the Tahoe forum. Are you losing the rear blower?
Old July 19th, 2008, 12:35 PM
Thanks for the reply. Yes, the issue is losing the rear blower that has independent switching from the front.
Old July 20th, 2008, 6:48 PM
Um yeah I got no input but...GO Horns!
Old July 20th, 2008, 10:03 PM
See where you are losing the voltage.
Old May 12th, 2009, 6:07 PM
cherbini's Avatar
Fairly dead thread, however....
The squirrel cage back there is katty wompus, the plastic gets hot, and the fan sticks to the housing that it's in.
It's easy to remove, and you can see that it will work fine when you take it out.
I've shaved mine down a few times now with a dremel. Gives me about a year each time.
I need a new one now though. That's why I'm here.
Anyone have a part number for the rear squirrel cage fan?
Any other suggestions on how to fix this?
Thanks!
John C.
Old May 12th, 2009, 7:29 PM
Welcome to the Tahoe forum. Looks like you got your answer.
Old May 13th, 2009, 11:52 AM
cherbini's Avatar
Got back into it last night, and found another part of the problem.
There is a foam tape that separates the fan motor mount from the housing it's screwed into. Foam gets played out / compressed, fan goes too deep in the housing, fan contacts housing heats up and melts together. No more spinning.
I cut the back lip out of the housing, and added some more foam tape to keep better separation.
It works!
Old May 13th, 2009, 9:28 PM
Thanks for sharing. Hopefully TL1971 will see it.
Old June 25th, 2009, 1:07 PM
dhawthorne15's Avatar
Thanks!
John C.
Where is this "squirrel cage" fan located at? I have the same problem.
Quick Reply: 2001 Tahoe rear AC system problems
