2001 Tahoe rear AC system problems
Old Jul 18, 2008 | 5:07 PM
TexasLonghorn1971's Avatar
Default 2001 Tahoe rear AC system problems
There is some sort of short in the rear AC system in my Tahoe. Once in awhile it works briefly after hitting a bump, but for the most part, it does not. Any ideas on how to fix this? The front AC works fine...
Old Jul 18, 2008 | 10:08 PM
Default RE: 2001 Tahoe rear AC system problems
Welcome to the Tahoe forum. Are you losing the rear blower?
Old Jul 19, 2008 | 12:35 PM
Thanks for the reply. Yes, the issue is losing the rear blower that has independent switching from the front.
Old Jul 20, 2008 | 6:48 PM
Um yeah I got no input but...GO Horns!
Old Jul 20, 2008 | 10:03 PM
See where you are losing the voltage.
Old May 12, 2009 | 6:07 PM
cherbini's Avatar
Fairly dead thread, however....
The squirrel cage back there is katty wompus, the plastic gets hot, and the fan sticks to the housing that it's in.
It's easy to remove, and you can see that it will work fine when you take it out.
I've shaved mine down a few times now with a dremel. Gives me about a year each time.
I need a new one now though. That's why I'm here.
Anyone have a part number for the rear squirrel cage fan?
Any other suggestions on how to fix this?
Thanks!
John C.
Old May 12, 2009 | 7:29 PM
Welcome to the Tahoe forum. Looks like you got your answer.
Old May 13, 2009 | 11:52 AM
cherbini's Avatar
Got back into it last night, and found another part of the problem.
There is a foam tape that separates the fan motor mount from the housing it's screwed into. Foam gets played out / compressed, fan goes too deep in the housing, fan contacts housing heats up and melts together. No more spinning.
I cut the back lip out of the housing, and added some more foam tape to keep better separation.
It works!
Old May 13, 2009 | 9:28 PM
Thanks for sharing. Hopefully TL1971 will see it.
Old Jun 25, 2009 | 1:07 PM
dhawthorne15's Avatar
Thanks!
John C.
Where is this "squirrel cage" fan located at? I have the same problem.
