2005 suburban - annoying squeak
Seems the drive shaft is squeaking when it rotates. The squeaking noises are faster than the rotation of the wheels. does anyone have a solution to stop this squeaking? is it just a lube fix, or are some bearings shot? i went under to see if i could find some lube points, but couldn't find any zerk fittings.
replace u-joints. they are likely the cause.
:chug:
