2004 Tahoe Blend Door problem
I'm get hot air from the driver side vent when the auto climate control is set at 60f. I have removed the actuator on the passager side and it is working fine. I have replaced it in the past to fix this problem. This time is different b/c when I move the blend door manually i still get hot air. I need help finding the part number if it is a bad blend door and any suggestions that you might have.
