2004 Tahoe Blend Door problem
Old Nov 27, 2015 | 4:36 PM
LouisianaGuy's Avatar
Default 2004 Tahoe Blend Door problem
I'm get hot air from the driver side vent when the auto climate control is set at 60f. I have removed the actuator on the passager side and it is working fine. I have replaced it in the past to fix this problem. This time is different b/c when I move the blend door manually i still get hot air. I need help finding the part number if it is a bad blend door and any suggestions that you might have.
Old Nov 27, 2015 | 5:28 PM
Here is my answer
Old Dec 6, 2015 | 11:11 AM
jason78's Avatar
Check rock auto or gm parts.com for part numbers then cross check Amazon for price comparison.
