Last edit by: IB Advertising
Browse all: Towing and Hauling
- Chevrolet Silverado 1999-Present GMT800, GMT900, K2XX Towing with 2WD
Important information to help you understand your Chevrolet Silverado
2005 Suburban 2500 LS 2WD--tow rating
link to owners manual for 2005 burb
http://www.ownersmanualsource.com/ch...owners-manual/
Vehicle" Axle Ratio MaximTur amWil eirg ht I GCWR
K-1500 (4 WD)*
4800 V8
5300 V8
Tongue weight should be 10 percent to 15 percent of the trailer weight up to 1,000 Ibs (454 kg).
I Vehicle* I Axle Ratio I Maximum Trailer Weight I GCWR
I C-2500 (2WD)*
6000 V8 8,200 Ibs. (3 722 kg)
(SuburbanNukon XL)t 10,200 Ibs. (4 630 kg)
14,000 Ibs. (6 356 kg)
16,000 Ibs. (7 264 kg)** 1 6000 V8 wI4WS 7,600 Ibs. (3447 kg)
9,600 Ibs. (4354 kg)
14,000 Ibs. (6 350 kg)
16, 000 Ibs (7 257 kg)
I 8100 V8 I 3.73 I 10,400 Ibs. (4 717 kg) I 17,000 Ibs. (7 718 kg)
I (Suburban/Yukon XL)t I 4.10 I 12,000 Ibs. (5 448 kg) I 14,000 Ibs. (6 356 kg)
*Tongue weight should be 10 percent to 15 percent of trailer weight up to 1,500 Ibs. (681 kg) maximum.
**GCWR limited to 14,000 Ibs. (6 356 kg) on vehicles with 283 suspension.
t2500 SuburbanNukon XL (ZWD) equipped with 283 base suspension limited to 7,900 Ibs. (3 583 kg) trailer
4-
K-1500 (4 WD)*
4800 V8
5300 V8
I C-2500 (2WD)*
4-
Official GM Rep
The Maximum tow weight for an LS 2500 2005 Suburban is 12,000 with the 4.10 rear axle ratio and 8.1L engine and with the 3.73 rear axle ratio with the same engine it can tow 10,300 pounds. If you have the 6.0L engine then that rating is either 7,700 pounds with the 3.73 rear axle ratio or with 4.10 rear axle the rating would be 9,700 pounds. I hope this information helps you. I also found this inforamtion in your owners manual section 4 page 66.
Jeff Morris, Chevrolet Customer Service
Danistheman1234
Suspension & Tire
November 25th, 2011 10:14 AM
