96 CHEV K2500 SUB 454 water pump?????
Old April 28th, 2008, 12:57 PM
ussva's Avatar
Default 96 CHEV K2500 SUB 454 water pump?????
I have a leak from under the water pump somewhere, not coming out of the hole at the top of the water pump. Leaks down the lower rad hose(replaced that, thinking it was the hose) any ideas? Seal maybe???
Old April 28th, 2008, 6:30 PM
RonH's Avatar
Default RE: 96 CHEV K2500 SUB 454 water pump?????
Check further into the water pump. Doesn't have to come out the hole in the top of the pump to be a water pump leak.
Old April 28th, 2008, 6:47 PM
ussva's Avatar
So, what do you figure it is Ron? Seal? Loose bolts?
Old April 28th, 2008, 8:07 PM
Banned
shawnvw's Avatar
Is the clamp on the hose tight?
Old May 16th, 2008, 10:33 AM
ussva's Avatar
Found another weeping hole under the water pump, I have replaced with a new water pump, everything is good to go! Thanks guys!
98BlueTahoe
January 8th, 2013 4:00 PM
ussva
March 18th, 2010 10:07 PM
jrsavoie
Silverado & Fullsize Pick-ups
February 24th, 2010 2:38 PM
ussva
June 19th, 2009 6:58 PM
ussva
January 25th, 2009 9:26 PM
Quick Reply: 96 CHEV K2500 SUB 454 water pump?????
