96 CHEV K2500 SUB 454 water pump?????
Old Apr 28, 2008 | 12:57 PM
ussva's Avatar
Default 96 CHEV K2500 SUB 454 water pump?????
I have a leak from under the water pump somewhere, not coming out of the hole at the top of the water pump. Leaks down the lower rad hose(replaced that, thinking it was the hose) any ideas? Seal maybe???
Old Apr 28, 2008 | 6:30 PM
RonH's Avatar
Default RE: 96 CHEV K2500 SUB 454 water pump?????
Check further into the water pump. Doesn't have to come out the hole in the top of the pump to be a water pump leak.
Old Apr 28, 2008 | 6:47 PM
ussva's Avatar
So, what do you figure it is Ron? Seal? Loose bolts?
Old Apr 28, 2008 | 8:07 PM
shawnvw's Avatar
Banned
Is the clamp on the hose tight?
Old May 16, 2008 | 10:33 AM
ussva's Avatar
Found another weeping hole under the water pump, I have replaced with a new water pump, everything is good to go! Thanks guys!
98BlueTahoe
Jan 8, 2013 4:00 PM
ussva
Mar 18, 2010 10:07 PM
jrsavoie
Feb 24, 2010 2:38 PM
ussva
Jun 19, 2009 6:58 PM
ussva
Jan 25, 2009 9:26 PM
