Heated Washer Fluid Available
#12
1 Post
I don't think there's enough volume of fluid to cause it to crack. When the hot fluid hits the cold windshield, it lowers the temperature immediately. I've used mine in below zero temps, and it worked fine. That was before I found out ithe tank was burning through! Then there was the spate of "mystery washer" events that would drain the washer tank, and that's when I stopped using it.
#13
The "fix" was a new harness w/ a fuse in it. When I have more time, will address the original problem and why the company went bankrupt.
croberts
May 7th, 2011 4:31 AM
