Old July 27th, 2015, 2:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
There is a TSB for that...
Old January 20th, 2011, 10:23 AM
Thumbs up There is a TSB for that...
2007-2009 Chevrolet Tahoe TSB
Engineering Information
• #08-08-61-001B: EI08027 - Underbody Noise, Pop, Creak, Groan, Clunk, Squeak, Body Mount (Install Insulator) - (Sep 10, 2008)
• #07-08-62-004B: EI07094 - Front Fascia Paint Concerns on Peeling and/or Scratches - Non GM Warranty Repair - (Sep 5, 2008)
• #06-08-64-037A: EI06034 - Liftgate, Door Handle Broke, Broken, Lock, Will Not Open, Inoperative - (May 7, 2008)
• #07-06-04-027B: EI07239 - 5.3L, LMG LC9 Driveability Symptoms, Hesitation, Miss, Lack of Power, DTCs, Check Engine Light, MIL, Injector (Diagnose and Repair Per SI) - (Nov 28, 2007)
• #07-08-44-018: EI07233 - Rear Seat Entertainment Does Not Work Properly, Blank Screen, Audio Heard But No DVD Playing, Video Screen Monitor Inoperative - (Aug 27, 2007)
• #07-03-11-001: EI07140 - Service Suspension Message (ECU) DTC C0550 C0895 (Engineering Investigation) - (May 10, 2007)
• #07-08-48-001A: EI07036 - End of Request for Front Windshield Glass Optical Distortion or Stress Cracks (Enginering Information) - (Mar 28, 2007)
• #07-06-03-003: EI07061 - Discharged Battery, Low Voltage, Long Crank, No Start (Engineering Information) - (Feb 23, 2007)
Technical
#01-07-30-032E: Transmission Oil Leaking From Transmission Vent (Replace Transmission Case Cover (Channel Plate) Gasket) - (Sep 29, 2008)
#07-06-05-001D: Muffler Buzz During Vehicle Operation or Exhaust Popping/Snapping Noise When Vehicle is Hot, at Idle or Immediately After Vehicle is Shut Off (Replace Straps on Muffler Heat Shield) - (Sep 26, 2008)
#08-01-39-009: HVAC Automatic Climate Control Defaults to Full Cold or Full Hot Despite Controls Being Set to Other Parameters, DTCs B0423, B0228, B3779, B0413, B3782, B0433 (Reprogram HVAC Control Module) - (Sep 16, 2008)
#06-08-61-003D: Underbody Pop or Clunk Type Noise While Turning or Driving on Uneven Road Surfaces (Install Body Mount Insulator) - (Sep 10, 2008)
#08-06-02-003: Engine Oil Leak at Engine Oil Cooler Hose/Pipe Assembly to Oil Pan Connection (Perform Outlined Repair) - (Sep 10, 2008)
#08-07-30-021B: Loss of High Speed GMLAN Communications, Intermittent No Crank, IPC Gauge Fluctuation, Intermittent Door Lock Cycling, Transmission May Not Shift, DTCs U0073, U0100, U0101, U0102, U0121, U0140 Set - (Sep 8, 2008)
#05-06-01-034F: 5.3L LC9, LS4, L33, LH6, LM4, 5.7L LS1, LS6, 6.0L LS2, L76 6.2L L92, 7.0L LS7 - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) - (Sep 4, 2008)
#08-03-08-002C: Front Shock Absorber Noise, Leaks, Service Suspension Message Displayed on DIC, DTCs C0575 and/or C0580 Set (Replace Shock Absorbers and Coil Springs, If Necessary) - (Sep 4, 2008)
#08-08-42-004: Overhead Dome and/or Reading Lamp Inoperative with Push Button Switch (Replace Switch(es)) - (Aug 27, 2008)
#06-08-44-033B: Radio - Poro AM and FM Reception (Inspect and Fully Seat Connector) - (Aug 25, 2008)
#08-08-110-013: Premature Wear or Worn Spots on Rubber/Vinyl Floor Covering (Replace Floor Covering) - (Aug 18, 2008)
#07-08-47-005A: Power Liftgate May Open or Close About a Third of the Way Then Reverses, DTCs B153E and/or B153F Set (Inspect Lfitgate Wiring Harness and Repair as Necessary) - (Aug 6, 2008)
#08-06-04-012B: EI08047 - Intermittent MIL/SES, DTC(s) P2120, P2122, P2123, P2125, P2127, P2128, P2138 with Reduced Engine Power (Replace Accelerator Pedal) - (Aug 6, 2008)
#06-08-45-009A: Rear Door Locks/Rear Windows/Courtesy Lamps/Rear Speakers Inoperative, Blown Fuse, SIR DTC Codes (Inspect/Repair, Wrap Wire Harness) - (Aug 4, 2008)
#08-08-42-003: Stop Lamps Intermittently Turn Off After Coming to a Complete Stop While Still Having Pressure on Brake Pedal (Replace Stop Lamp Switch) - (Jul 23, 2008)
#07-06-01-007B: Excessive Engine Oil Consumption (Verify Condition, Inspect Valve Stems, Replace Cylinder Heads, If Necessary) - (Jul 18, 2008)
#06-06-03-013C: Intermittent Low Battery Voltage, Engine Will Not Crank, Engine Cranks But Will Not Start, Charging System Light On, Service Battery Charging System Message Displayed, DTC B1516 Set (Reprogram BCM) - (Jul 14, 2008)
#06-02-35-003B: Rub or Squeak Noise While Turning, Steering Wheel Slowly Returns to Center and/or Increased Steering Effort (Replace Steering Column Seal and Shim Lower Steering Column Mounting Locations, If Necessar - (Jun 27, 2008)
#08-06-03-007: No Start, No Crank, Intermittent Electrical Operations (Check for Poor Connections Within Engine Wiring Harness Junction Block) - (Jun 27, 2008)
#08-08-46-002: OnStar Calls Unwanted, False Crash Detection Customer Calling (Reprogram SDM) - (Jun 26, 2008)
#08-07-30-027: No Movement When Transmission is Shifted to Drive or Third - Normal Operation When Shifted to Second, First or Reverse (Replace Forward Sprag Assembly) - (Jun 4, 2008)
#08-08-61-005: Front and/or Rear Wheelhouse Panel Liner Wavy or Warped (Apply Heat and Reform Wheelhouse Panel Liner) - (Jun 4, 2008)
#06-02-35-013A: Rub or Squeak Noise While Turning at Slow Speeds (Bulletin Canceled - Refer to Bulletin 06-02-35-003A) - (May 30, 2008)
#08-08-127-001: Park Assist System Inoperative, Service Park Assist Message on DIC, DTC B1E3A and/or B0954, P0955, B0956, B0957, B0958, B0959, B0960, B0961 (Replace Appropriate Object Sensor or Repair Harness) - (May 30, 2008)
#08-08-63-001: Rattle Noise From Front of Vehicle at Highway Speeds (Replace Upper Radiator Baffle Retainers) - (May 29, 2008)
#07-08-46-002B: Audio Whine Noise from Radio Speakers When Using OnStar (Install Noise Suppression Filter) - (May 20, 2008)
#08-08-44-002A: Navigation Radio Clock and/or Clock Tab Do Not Appear or Disappears Intermittently, Split Screen, Points of Interest or an Exit List Apepars While Driving, Text Color may be Difficult to See - (May 16, 2008)
#08-08-64-007: Squeaky Outside Door Handle (Grease U-Channel of Handle) - (May 13, 2008)
#08-07-30-023: 4L60-E/4L65-E/4L70-E Automatic Transmission Fluid Leak from Oil Pump or Bell Housing Area (Replace Torque Converter Hub-to-Oil Pump Seal Assembly) - (May 8, 2008)
#08-03-10-006: Tire Slowly Goes Flat, Tire Air Loss, Low Tire Pressure Warning Light Illuminated, Aluminum wheel Bead Seat Corrosion (Clean and Resurface Wheel Bead Seat) - (May 1, 2008)
#08-02-32-001B: Power Steering, Steering Wheel Shudder/Vibration During Low Speed Parking Maneuvers (Replace Power Steering Assembly Hose) - (Apr 30, 2008)
#08-08-48-003: TIcking Noise at Windshield Area (Replace Windshield Reveal Molding with New Design Molding) - (Apr 28, 2008)
#08-02-35-004: Steering Wheel Spoke Cover Warped, Loose, Discolored or Fits Poorly in Steering Wheel (Replace Steering Wheel Lower Cover, As Needed) - (Apr 22, 2008)
#07-08-110-010A: EI07321 - Inner Door Panel Rattle Noise/Loose (Inspect/Replace Clips) - (Apr 14, 2008)
#06-08-44-032B: Rear (2nd and *3rd Wor (*where applicable)) DVD Screen Blank/Inop, Speaker Pop Noise, Battery Draw, OnStar Audio Inop, Nav Screen/Radio Display Flashing (Inspect/Repair Wiring Harness, if Necessary) - (Apr 10, 2008)
#08-09-41-005: Passenger SIde Air Bag Door Not Flush with Dash Pad/Warped (Reppsition Locking Tabs on Air Bag Panel) - (Apr 9, 2008)
#06-08-64-035E: Squeak/itching Noise in Upper Door Area (Install Squeak Reduction Tape) - (Apr 9, 2008)
#07-08-50-002B: Third Row Passenger Seat May Not Fold Down Flat and/or Hight Effort to Release Seat Back, Right Rear Seat Latch May Not Disengage (Replace Inboard Recliner Latch and Cable) - (Apr 4, 2008)
#08-08-44-005A: Radio Volume Fluctuation, Excessive Static, Weak Reception on Medium Strength FM Stations (Reprogram Radio) - (Mar 12, 2008)
#08-08-110-004: Gap Between Primary Weatherstrip and Lower Rear Quarter Trim Panel (Install Foam Block) - (Mar 11, 2008)
#08-08-45-002: Left or Right Power Outside Mirror Inoperative (Inspect Wire Harness) - (Mar 4, 2008)
#07-08-43-010A: Windshield Wiper Streak at Low Vehicle Speeds (Replace Windshield Wipers and Arms) - (Mar 3, 2008)
#07-08-50-017A: Front Power Seat Vertical Motor Inoperative, Seat Binds or Sticks in Full Up or Down Tilt Position (Install New Stops) - (Feb 22, 2008)
#08-08-110-003: Gap Between Primary Weatherstrip and Lower Body Lock Pillar Trim Panel (Install Foam Block) - (Feb 21, 2008)
#07-08-50-019A: Third Row Seats Hard to Install (Retorque Latch Bolts or Replace Seat Roller Bar) - (Feb 7, 2008)
#08-08-50-001: Front Seat Cushion Cover Becomes Detached (ApplyTape to Frame) - (Feb 4, 2008)
#07-08-49-029A: Instrument Panel (IP) Gauges/Gages Difficult to Read or See, Poor Backlighting (Replace IP and Program) - (Jan 25, 2008)
#05-03-10-003C: Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) - (Jan 15, 2008)
#07-06-04-034: 6.0L (LY6/L76) Engine - Low Power, 4L70/4L80/6L90 Automatic Transmission - Hesitation, Difficult to Obtain Downshifts (Reprogram TCM and/or ECM) - (Dec 18, 2007)
#07-09-41-010: Airbag Light On, DTC B0071 and B0081 Set (Diagnosis and Replace Right Front Seatbelt Buckle, If Necessary) - (Dec 17, 2007)
#07-08-50-022: Seat Rattle and/or Hard to Latch and Unlatch (Install Washer) - (Dec 11, 2007)
#03-06-04-030F: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976) - (Dec 10, 2007)
#07-06-01-023: 60 Degree V6 Engine Oil Leak at Crankshaft Front Oil Seal (Use New Crankshaft Front Oil Seal Installer Tool EN-48869) - (Dec 5, 2007)
#07-06-04-013A: L76 4L70-E Chuggle, Surge, Hesitation May Be Felt with Active Fuel Management System Cylinder Deactivation Transition from V8 Mode to V4 Mode or Harsh 1-2 Upshift (Reprogram ECM and TCM) - (Nov 26, 2007)
#07-02-32-008A: Steering Wheel Off Center While Driving Straight, Clunk Noise While Turning, Early Front Tire Wear (Perform Torque to Tighten Analysis and Repair as Necessary) - (Nov 21, 2007)
#07-08-64-019: Front Door Window Regulator Squeak Noise When Operated (Apply Lubricant) - (Nov 13, 2007)
#06-03-09-007B: Squeak, Rattle or Clunk Noise in Rear Suspension Over Bumps, During Acceleration or While Braking (Inspect/Rotate Rear Coil Springs and Inspect Lower Control Arm Bolts For Proper Torque) - (Nov 1, 2007)
#07-04-21-002: Intermittent Service 4 Wheel Drive Message Displayed in DIC, DTC C0378 Set (Diagnose and Reprogram Transfer Case Control Module (TCCM), if Necessary - (Oct 29, 2007)
#07-04-17-002: Whine Type Noise Coming From Rear of Vehicle (Diagnose and Replace Rear Propeller Shaft) - (Oct 25, 2007)
#05-06-01-019F: Engine Oil Leak at Crankshaft Rear Main Oil Seal (Install Revised Crankshaft Rear Main Oil Seal Using Revised Rear Main Seal Installer and Remover Tools) - (Oct 2, 2007)
#07-08-50-018A: Excessive Lint Accumulation on Cloth Seats (Parts Not Yet Available) - (Oct 2, 2007)
#07-01-38-010: Air Conditioning Compressor and/or Serpentine Belt Noise at Vehicle Startup with Ambient Temperature Above 35 Degrees Celsius (95 Degrees Fahrenheit) - (Oct 1, 2007)
#07-08-49-018: Various Electrical Concerns-Intermittently Functioning or Inoperative Component, IP Warning Light On, DIC Message Displayed, DTC Set, No Crank/Start (Repair IP Wiring Harness) - (Sep 7, 2007)
#06-08-64-027E: Left Outside Rearview Mirror Glass Shake or Flutter (Relearn Power Mirrors and Replace Left Mirror, If Necessary) - (Aug 30, 2007)
#07-08-44-016A: GM Accessories Headrest DVD System Display Monitor Inoperative (Install Cable Connector Clamps) - (Aug 28, 2007)
#06-08-66-012C: Windnoise From Rear of Vehicle/Liftgate Glass (Replace Seal, Stop Bumpers and Rear Glass) - (Jul 31, 2007)
#06-08-52-002F: Remote Keyless Entry (RKE) Inoperative, Poor Range, Tire Pressure Monitor (TPM) Message Displayed, Remote Vehicle Start (RVS) (Replace RKE Transmitters and Reprogram Remote Control Door Lock Receiver) - (Jul 31, 2007)
#06-08-63-001A: High Closing Effort of Hood (Align Hood Latch) - (Jul 19, 2007)
#07-09-40-001: Front Seatbelt Latch Plate Reversed, Front Seatbelt Twisted (Perform Repair to Untwist Seatbelt) - (Jul 11, 2007)
#07-06-04-019: Intermittent MIL/SES, DTC P2138 with Reduced Engine Power (Repair Instrument Panel (IP) to Body Harness Connector) - (Jun 21, 2007)
#06-08-49-007B: Instrument Panel (IP) Upper Trim Panel Loose, Buzz or Rattle Noise from Front of IP or Base of Windshield (Install New Clips to IP Upper Trim Panel and Add Felt to Blade Seal) - (Jun 7, 2007)
#07-08-59-003: Loud Buzz or Rattle Noise from Right Front Fender Area on Moderate to Hard Acceleration and/or Braking Torquing Around 1800-2000 RPMS or Before 1-2 or 2-3 Shift (Install Closed Cell Foam to RF Fender) - (Jun 6, 2007)
#99-01-39-004B: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating) - (May 29, 2007)
#06-02-32-010A: Power Steering High Pitched Whistle Noise Heard in Any Gear with Vehicle Warm (No Fix Available at This Time) - (May 22, 2007)
#07-08-50-010: Driver Seat Squeak or Creak Noise (Replace Bottom Seat Frame) - (May 9, 2007)
#05-08-51-008B: Bumps or Rust Colored Spots in Paint Due to Rail or Iron Dust (Remove Rail Dust) - (Apr 23, 2007)
#07-08-44-008: No Audio/No Sound Heard from Radio Speakers, Turn Signals, Hazard Signals and No Warning Chimes When a Door or Liftgate is Opened (Inspect/Seat C2 Audio Amplifier Connector) - (Apr 18, 2007)
#06-08-44-026A: Rear Video Screen Inoperative - Blank/Black DVD Screen with Audio Present (Exchange DVD Unit) - (Apr 17, 2007)
#07-01-37-002: Coolant Leak at Rear of Vehicle (Install Auxiliary Heater Inlet and Outlet Hose Quick Connector Service Kit) - (Mar 30, 2007)
#07-06-01-004: All Vortec GEN IV V8 Engines - LY2 LS4 LC9 LH6 LMG LY5 LS2 L76 LY6 L92 LS7, Low Oil Level Indicator Lamp On and/or Engine Oil Leak (Reseal Oil Pressure Sensor) - (Mar 16, 2007)
#06-08-57-001A: General Waterleak Diagnostic Guide - (Mar 13, 2007)
#07-08-61-004: Articulating Running Boards (Assist Steps) Inoperative (Reprogram Assist Step Controller) - (Mar 12, 2007)
#07-08-50-004: Squeak Noise from Third Row Seats (Properly Seat Escutcheons Over Seat Strikers and Apply Flock or Felt Tape to Seat Bars) - (Feb 16, 2007)
#06-06-03-011B: Hum or Buzz Noise From Rear of Vehicle and/or Possible Dead Battery (Check Fuel Pump Relay and Replace, if Necessary) - (Feb 16, 2007)
#07-08-61-001: Assist Step Rocker Cover Gap to Rear Door (Install Assist Step Rocker Cover Brackets) - (Feb 6, 2007)
#07-08-43-002: Windshield Washers Not Spraying Properly (Install Foam Washer) - (Jan 31, 2007)
#07-09-41-002: Air Bag Light On, DTC B0081 Set (Clear DTC Using Specific Procedure) - (Jan 29, 2007)
#07-08-43-001A: Rear Wiper Arm Broken/Inoperative After Using Automatic Carwash (Install Updated Rear Wiper Arm Park Ramp/Stop) - (Jan 26, 2007)
#07-08-49-002: Front Floor Rear Console Cupholder Does Not Properly Retain Drink Containers (Install Updated Rear Console Cupholder Liner) - (Jan 24, 2007)
#07-08-49-001: Various Electrical Concerns - Hood Open Message Displayed, Door Locks Inoperative, Brake Warning Lamp On (Replace BCM and Install Connector Service Kit) - (Jan 18, 2007)
#07-08-62-001: Headlamp Not Flush to Front Fascia (Adjust Front Fascia Bracket) - (Jan 3, 2007)
#06-08-127-002: UVC Rear Vision Camera System Inoperative (Inspect for Missing CPA Retainer and/or Properly Seated Connector/Connection at Camera) - (Nov 9, 2006)
#06-09-41-007: SIR Supplemental Inflatable Restraint Message, DTC B0081, B0071 Set, MIL Light On (Repair and Reroute Wiring as Necessary) - (Nov 9, 2006)
#06-08-45-009: Rear Door Locks/Rear Windows/Courtesy Lamps/Rear Speakers Inoperative, Blown Fuse, SIR DTC Codes (Inspect/Repair, Wrap Wire Harness) - (Oct 31, 2006)
#06-08-44-037: Navigation Radio Operation - Low Radio/OnStar Volume, Map Disk Error, Clock Does Not Update in New Time Zone (Reprogram Radio and/or Refer to Navigation Supplement-Owners Manual) - (Oct 24, 2006)
#06-08-50-006A: Third Row Seat Difficult to Remove and Install (Remove Excessive Sealant) - (Oct 23, 2006)
#06-08-64-026B: Rear Door Outer Belt Sealing Strip/Molding Bowed, Loose (Replace with New Design Outer Belt Sealing Strip/Molding) - (Oct 10, 2006)
#06-08-50-012: Front Driver or Passenger Power Seat Adjust Functions Inoperative and/or Driver Seat Memory Inoperative (Check Power Seat Switch Connector) - (Oct 6, 2006)
#06-01-39-005B: EI06052 - HVAC Not Cooling, A/C Not Cool (Perform A/C Performance Test Per SI) - (Oct 6, 2006)
#06-08-44-031: Buzz, Pop or Whine Noise from Any Speaker (Secure Wiring Harness) - (Oct 4, 2006)
#06-06-04-042A: LR4, LY2, L33, LH6, LM7, L59, LC9, LMG, LY5, LS2, LQ9, LQ4, L76, LY6 Throttle Actuator Control (TAC) Module Codes, MIL/SES DTCs P2108 P1516, U0107, Reduced Engine Power (Reprogram PCM) - (Sep 25, 2006)
#06-06-05-005: Residue on Exhaust Resonator and/or Tailpipe (Clean Off Welding Residue with Brake Cleaner) - (Sep 12, 2006)
#01-07-30-038D: Diagnostic Trouble Code (DTC) P0757 Set, Malfunction Indicator Lamp (MIL) Illuminated, Poor Performance of Transmission/Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (Sep 12, 2006)
#06-08-45-007: No Start/Loss of Low Speed LAN/DTC Set (Repair/Reroute Wiring) - (Sep 12, 2006)
#06-08-49-019: Rattle Noise from Center of Instrument Panel Carrier (Add Felt Tape to OnStar Module Support Bracket) - (Sep 8, 2006)
#06-01-39-008: Automatic HVAC System Set Temperature Does Not Provide Comfort (Update HVAC Control Module Software) - (Sep 7, 2006)
#06-07-30-017A: 4L60-E, 4L65-E, 4L70-E, Automatic Transmission High Pitched Whine, Whistle, Chirp or Buzz Type Noise at 1,500-1,800 RPM (replace with Updated Torque Converter) - (Aug 16, 2006)
#06-08-64-029: Whistle Noise Heard with HVAC Blower on High (Install Foam Strip in Door Handle) - (Aug 11, 2006)
#06-08-46-004: Navigation Radio Voice Recognition is Inoperative, May Not Follow Customer Command or May Not Recognize Customers Voice (Follow Diagnostic Procedure) - (Aug 1, 2006)
#06-08-64-014A: Door Locks, Power Windows, Door Courtesy Lamps, Heated/Cooled Seat Indicators Inoperative (Reprogram Driver and Passenger Door Switches) - (Jul 20, 2006)
#06-07-30-016: 4L60-E, 4L65-E Automatic Transmission Fluid Leak from Oil Pump or Bell Housing Area (Remove Burrs on Torque Converter Hub, Pump Drive Slots, Replace Torque Converter Hub-to-Oil Pump Seal Assem. (243)) - (Jul 18, 2006)
#06-09-40-002: Passenger Safety Belt Reminder Light Remains On After Remote Start (Perform Appropriate Correction Action Below) - (Jul 13, 2006)
#06-08-66-010: Squeak Noise at Rear of Vehicle Over Bumpy Roads (Install Washer) - (Jun 27, 2006)
#06-06-02-007: LY2, LY5, LY6, LH6, L76, LMG, LC9, L92, Coolant or Rubber Type Odor, Loss of Engine Coolant and/or Overheat Condition (Add Second Clip to Upper Radiator Hose) - (May 9, 2006)
#05-08-64-002B: Door Latch Freezing in Cold Temperatures (Apply Super Lube) - (Apr 3, 2006)
#06-06-04-001A: Service Engine Soon (SES) Light On/Diagnostic Trouble Code(s) (DTC) P0300, P0171 and P0174, Active Fuel Management Misfire Due to Fuel Injector Connectors Crossed/Swapped/Incorrectly Installed - (Mar 29, 2006)
#06-08-47-002A: Power Lift Gate/Liftgate Remains Locked (Reprogram BCM and Lift Gate Module (LGM) with Updated Software) - (Mar 28, 2006)
#06-08-64-012: Power Folding Outside Rearview (OSRV) Mirror Whistle Noise (Add Foam) - (Mar 17, 2006)
#02-06-04-015A: Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt) - (Mar 7, 2006)
#05-06-05-003: Information on Hot Plastic Odor Emanating from Exhaust During Initial Run-In of Vehicle - No Fix Required - (Dec 22, 2005)
Post is for reference only
Last edited by in2pro; February 8th, 2012 at 8:33 PM. Reason: Un-sticky-ed its been up for a year..
Old May 4th, 2012, 6:50 AM
New User
Awaiting E-mail Confirmation
shrbob's Avatar
2008 GMC - at 100000 the service park assist on dash came on - sencors are clear
Old May 4th, 2012, 7:29 AM
SabrToothSqrl's Avatar
Wow... was there anything they assembled correctly?
Old July 16th, 2012, 9:25 AM
New User
57will's Avatar
can you claear codes on 2007 tahoe by un hooking negative on battery?
Old July 16th, 2012, 10:00 AM
Yes, but typically the positive cable is done...
The vehicle may run slightly different after start up as some things are "relearned" if you can have the codes cleared with a code reader with clearing capabilities..
Old October 9th, 2012, 4:41 PM
DONNAJ's Avatar
I have a 2011 Chevy Silverado with the ebony cloth interior. Does anyone know how to remove the lint from the seats? It's horrible!!
Old October 9th, 2012, 4:44 PM
Welcome to the forum...
Lint roller? I thought the seat material was changed to address this issue as it was also seen on the 07 models...
Old October 9th, 2012, 4:47 PM
Here is the TSB for the lint issue
check your VIN for eligilibity:
Subject Excessive Lint Accumulation on Cloth Seats (Replace Seat Covers) #07-08-50-018 - (08/28/2007)
Models: 2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
with Cloth Seats (RPOs AE7, AZ3, A95)
Built Prior to August 1, 2007
Condition:
Some customers may comment on excessive lint accumulation on the cloth seat material. Darker colored seat fabric seems to show the condition more than lighter fabrics.
Cause:
The source of the lint accumulation is not the seat fabric material. The seat material, though, exhibits a tendency to accumulate and retain lint from sources that come into contact with the fabric.
Correction:
Replace the seat covers (back and cushion) with new covers that have been created with a revised fabric. Refer to SI for the appropriate seat back and cushion cover replacement procedures.
Parts Information
Important: These seat covers are ONLY for vehicles with an ebony interior.
Part Number
Description
25863790
Cushion - Driver (Pickups)
25863786
Cushion - Passenger (Pickups)
25863782
Seat Back - Front (Pickups)
25863656
Cushion - Driver (Utility)
25863508
Cushion - Passenger (Utility)
25863492
Seat Back - Front (Utility)
25863605
Cushion - Rear Seat 40%
25863601
Cushion - Rear Seat 60%
25863597
Seat Back - Rear 40%
25863593
Seat Back - Rear 60%
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
C6870
Cover and/or Pad, Front Seat Cushion - Right -- R&R or Replace
Use Published Labor Operation Time
C6871
Cover and/or Pad, Front Seat Cushion - Left -- R&R or Replace
C7050
Cover and/or Pad, Front Seat Back Cushion - Right -- R&R or Replace
C7051
Cover and/or Pad, Front Seat Back Cushion - Left -- R&R or Replace
C7250
Cover and/or Pad, Rear or Row 1 Seat Cushion - Right -- R&R or Replace
C7251
Cover and/or Pad, Rear or Row 1 Seat Cushion - Left -- R&R or Replace
C7270
Cover and/or Pad, Rear or Row 1 Seat Back Cushion - Right -- R&R or Replace
C7271
Cover and/or Pad, Rear or Row 1 Seat Back Cushion - Left -- R&R or Replace
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Old October 10th, 2012, 8:40 PM
cleveland63b's Avatar
all manufacturers have huge lists of tsbs and recalls
Old October 10th, 2012, 8:56 PM
Ain't that the truth... Toyota is recalling 7.4 MILLION vehicles for a power window issue that may cause fires...
Quick Reply: There is a TSB for that...
