2007 tahoe rear window defrost wire broke
Old March 25th, 2010, 2:00 PM
crosskeystv's Avatar
Default 2007 tahoe rear window defrost wire broke
The conector that is glued to the rear window for the defrost grid built into the window broke off. The conector is still in the wire plug. I can remove it and reglue it on the window. Is there a special glue or should I be looking for a new window?
Old March 29th, 2010, 12:25 PM
You can try the defroster grid repair kits. They utilize a copper loaded conductive epoxy. Disconnect the terminal and glue it on. Also stretch the cord so that when the glass is in the closed position, there is no stress on the connector. This is about a 50-50 chance.
Old March 29th, 2010, 9:31 PM
Professional Mechanic
MDTAHOE's Avatar
Yes can can be re glued with special glue for that. Both of mine came off I got the first stuff from Fisher Auto parts ( I can not remember who makes it) It worked great. When the other side came off I got Permatex brand from Auto Zone It fell right back off. I then used the first stuff and it has still not come back off. You can always go to a glass company.
Old May 25th, 2010, 12:14 AM
Brewboy's Avatar
Default Rear Defrost Tab TSB
Guys there's a TSB on that repair ...
I had my 07 Yukon fixed....its a bad design and dealer told me if its not fixed right after tab being repaired they will replace entire rear glass under warranty
Check it out on Techline
ncfr2544
January 2nd, 2022 9:33 AM
93Cavi22
September 13th, 2014 7:52 PM
ambiguous216
January 19th, 2014 9:01 PM
johnbhale
November 13th, 2012 3:34 PM
haidangwa
June 9th, 2007 8:47 AM
Quick Reply: 2007 tahoe rear window defrost wire broke
