Changed Plugs Truck running Rough - Help!
#11
Ran O.K. before. What I did was we had installed the AC delco plugs, so I cleaded the black off of the tops of each plug, used scotch bright on the contact point where the coil assy rubs against the head when installed, and stretched out each spring inside the rubber boot, going from the coil assy to the plug. Worked a little better, so I then got some different Autolight plugs that didn't have the black coating on the tips and worked better.
chevylover
Engine Building & Overhauling
December 17th, 2009 11:09 AM
zpig03
Silverado & Fullsize Pick-ups
November 4th, 2009 8:51 PM
victorramboman
October 20th, 2008 1:06 AM
dbrog28301
Colorado
May 21st, 2007 9:48 PM
